R56 Timing chain tensioner DIY
This is about the closest to a DIY here on the site:
https://www.northamericanmotoring.co...tensioner.html
Having done it myself and looking back on those directions, I'm not sure how helpful they are. Basically all you need to do is remove the airbox and one hose to access the tensioner. Take it out, put the new one in, then replace everything. I think it only took me about 45 minutes and most of that time was spent trying to loosen the tubes where they connected to get them free.
You'll need a 27mm socket which I believe is the same size as the oil filter housing, so if you are doing your own oil changes, you should have all the tools you need (assuming you have a torque wrench as well).
If all the dealer does is replace the tensioner, then it is relatively cheap. Part is $60+/- and then an hour labor. However, usually the problem manifests itself as a rattling noise. The diagnosis process includes a measurement of the chain and if it is beyond a certain length, the entire timing chain, gears, guides, etc., have to be replaced. That is about a $1,500 - $2,000 job (depends on the dealer for actual price).
on
Just finished installing the new tensioner. It's the same length as what's in there but stiffer. After install, there was no "diesel" sound, It's cold where I'm at, leading me to think that the tensioner is the cause of the cold start rattle. My thinking is if the chain were out of spec the equal length replacement tensioner would not stop the rattling. I'll report if the rattle goes away after tomorrow morning. It's supposed to get cold again tonight.
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
iamcamkeenan
08-10-2015 03:31 PM
