R56 brake pad recommendations?
on
For what it's worth, after reading a bunch of threads on here debating between Hawks and Redstuff, I ended up going with StopTech from TireRack. From what I could find they offer a better initial bite than the others which is appealing to me. I just ordered them so I can't review, but another option to consider. I think it was $65 for the fronts.
on
When I do mine I think I will go OEM.
I put the greenstuff pads on two different cars.
They threw out so much brake dust it was silly.
I'm still driving my CRX with the greenstuff.
It's annoying.
They stop slightly better I can not say phenominally
than just the high end wearever I get from advance auto.
Just my .02.
It's annoying.
Just my .02.
I just put new NM rotors and Redstuff pads on all four corners. I have Redstuff on all my cars including my SLK55 AMG. The pads just last longer than anything else I've used...about 40% longer. So from a cost point they end up breaking even for the cost of the pads but unless you install them yourself, you get to pay the installation twice. If so, you save money...if not going for a cheaper pad ends up costing more.
From the performance side they are low dust with a decent first bite and great heat dissipation.
Just like many other things, you get to choose your own and then you own your choice!
Vendor
I would recommend the EBC Redstuff over everything else. But if you need something cheaper the only thing that I would even consider would be the Akebono pads. You do get what you pay for.
My StopTech street performance pads were $55 for the set. Cheap but I will bet you I won't have any brake fade on the track if I went up against you.
Thanks for the help everyone. I really just can't afford the $100 for the redstuff for the front, in addition to the $20 sensor, so I'm going to go with the akebonos. If they give out prematurely 20,000 miles down the road, so be it, I will hopefully be able to afford the redstuff by then.
squawSkiBum
Tires, Wheels, & Brakes
26
03-18-2024 07:21 AM
Tires, Wheels & Brakes
08-26-2015 10:28 AM
08-25-2015 09:18 AM
