Greetings - Just got OBD II through a Garmin App, for starters, and it's the first time I've seen a temp reading. Awesome! What is considered the normal operating temp for the Gen 2 S? Thanks!
My freeway operating temp is always 225 steady, 215ish around town. If I get on it uphill or in higher gears it'll jump to 227, sometimes as high as 231 and then back down. I heard somewhere that once it goes past 231 you're in trouble...not sure. This is just off the Scangauge II.
Agreed, but how low does it go when the car is 'pushed?' I can't seem to find any concensus on the matter... Shouldn't it hit a low temp and regulate there, and if so, what is that temp?
Damn now I'm getting concerned about my temps. Once my car's heated up it pretty much stays at 225 or a couple degrees below. Under full throttle in higher gears it'll hit 227, then 229, sometimes 231, and then go back down. The difference in these temperatures compared to what people are posting is concerning me...anyone have any ideas?
If you see it hotter than you like, just turn on the AC to MAX. Watch the temp drop like a rock. The thermostat and water pump are controlled by the ECU.
An intercoler will have zero, zip, nada effect on coolant temp.
At temperature, I've been seeing one side or the other of 220ish. I figure I'm OK there based on what you guys are saying. Sport mode doesn't matter or affect my temp at all. What I don't like is my short commute especially that I don't get up to temperature. I get to work and I may still be sub 180. My OCC has been collecting alot of crap lately and with the cooler temps this can't be good for the long term. After work, I've been driving around, taking the looong way home just to warm it up.
