R56 MCS 08 Removing Intake VANOS Unit Fastening Bolt
I am attempting timing chain work on my girlfriends 2008 S (N14).
My trouble is removing the intake VANOS unit fastening bolt. I've put a good amount of torque on it with a breaker bar and a E14 socket but it hasn't moved. It is very tight there.
Will moving the front to service position help. Do I need to get a pneumatic tool in there? If so, how? Should I apply some heat to loosen it? I really don't want to strip the top off that E14 bolt.
Thanks,
Pudgies Mechanic
Thanks,
Pudgies Mechanic
Thanks,
Pudgies Mechanic
Thanks,
Pudgies Mechanic
Those E-sockets can be a pain. We're starting to use them a lot on the engines at work and you can wreck the bolt heads if you're not careful. Just make sure the cam is locked and you've got the socket nice and square on the bolt and it'll come right off if you've been doin' your bicep curls
09R56
11-16-2022 10:49 AM
minipopkart
08-13-2015 05:22 AM
