R56 R56 N18 obd2 data logging tool? similar to VAG-COM?
Ive got a 2011 r56 n18 engine cooper s turbo
Greetings, I come from the world of VAG (volkswagen)...i was wondering, what are you guys doing to log your cars via obd2 port?
For vw there is a tool called vag-com, it is the official data logging tool for vw's...it gives you acces to all control modules, measuring blocks, self adaptions, output test ect....with this tool you can also reprogram things on the ecu via laptop....things like headlight brightnes, daytime running lights, washer motor delay, windows up via key fob ect, disable seatbelt chime...
Is there an official data logging tool for our mini's similar to VAG-COM?
I need something that will let me
log measuring blocks
Maf sensor G/S
Fuel trim adaptation shrt and long term
lambda afr
boost pressure request/actual, wastegate duty cycles
throttle body angle
ignition timing
timing advance
knock sensors
Fuel rail pressure
Injector timing
Basically everything....
Also something that will allow me to perform self adaptations on the throttle body, tumble flaps, headlight self leveling ect...
Thnx in advanced, any former vw guys plz chime in, thanks!
Maf sensor G/S
lambda afr
throttle body angle
ignition timing
timing advance
knock sensors
Fuel rail pressure
Injector timing
trw92a
08-26-2015 01:47 PM
