LCI tail lights fitted in pre facelift but with check lights
I did the wiring and all is well the lights are on and working perfectly but there is a check light in my dash regarding my lights...what to do..? Any tutorials
The FRM will need to be coded for the change, however there is a possibility you will need to update the FRM2 to FRM3 and/or the software revision on the FRM will need to updated to support the retrofit. I haven't seen what specific codes or changes are necessary for this change. It maybe just as simple as disabling the warm and cold bulb checks on the rear parking/running lights.
As a crude workaround, you could try a load resistor across the running lights circuit (like people do when they replace a standard bulb with an aftermarket LED bulb).
^ yeah, a load resistor might work. You basically have to fool the car's ECU into thinking that the rear bulbs are not blown. LCI tails have LEDs which dont draw as much current as filiment bulbs and the ECU thinks the bulbs have gone bad.
I got myself a pair of the lci rear lights on ebay for my 07 mcs. It was kind of an impulsive purchase, but nonetheless I want to at least give the installation a go... Are there any tutorials or how tos?
Cheers
Hi fellow mini lovers,
Cheers
Hi titish, how did you do the wiring? I bought a pair of tails from an LCI Clubman and I found the connector totally different! I would appreciate any help given. Thanks!
