R56 Rim advice -et35 turini
Hi guys,
I'm looking at buying a set of speedline turini rims. They are 17x7 et35. Will these be a direct bolt on with my 2009 r56 Mini Cooper s with stock suspension? I'm just a little unsure about the offset? Can anyone let me know if these will fit?
Also, any advice on how I can get tpms in these rims?
Dane
Dane
Yes they should fit. But we need more specs on the rim. I tried looking them up but could not find much info http://www.speedlinecorse.co.uk/afte.../after2120.htm You might want to contact them and get more details. They will be with this offset very close to the edge of the fender and if you ever plan on lowering your MINI they may rub. You might be able to transfer the sensors from you old rims or buy new ones to add to them.
Thanks for your reply,
These are the rims here: http://www.lohen.co.uk/shop/proddeta...micsProRace1.2
Any suggestions on tyre size also?
If you are not going to lower it you can go with 215/45/17. If you lower it go 215/40/17 or 205/45/17.
I don't know where you are but you can get them here.
http://www.outmotoring.com/mini-coop...-pro-race.html
malibujoey
11-09-2015 08:22 PM
