R56 Back to the dealer again!
Hello this is my first post on here I believe... So last summer had to get the timing chain/ tensioner replaced. So the past few days been hearing that god awful noise again only when I start the car and drive for like 5 min then it goes away. But only happens I the car sits for a couple hours or more and start it back up. No lights flashing or anything yet like when I heard the noise before getting it replaced. So I am taking it back tomorrow to get looked at. Just annoyed! Had the thermostat replaced as well recently. Love the mini but it has became an investment. Any pointers for when I take it back in tomorrow? And yes I checked the oil it's all good.
Good luck. Had my tensioner go bad as well as my chain guide break into pieces, preventing me from being able to insert my dipstick all the way in (not a metaphor).
$1500 later and it got fixed. Could've been more butt mechanic saved me 9.0 labor hours by lifting the motor straight up and out. The official method is to remove the front end and grab another $1k or so from your wallet. That's why it's good to find a good mechanic, as a Mini dealer has to do it by the (expensive) book.
And now my airbag light is on. $180 just to tell me what the issue is. :/
'07 R56 / 88k miles
'07 R56 / 88k miles
Any guidance or tips would be appreciated
If you don't hear the noise don't take it in. I bet it was the low oil. Don't know how many miles you drive but I try to check every time I get gas. One other small check you can do is to make sure the tensioner bolt hasn't backed out at all or is slightly loose. Keep it tight!
Amber, my guess is your oil was in fact low when you checked it first and it only appeared overfilled after you checked it again. The way the MCS dip stick works, there is often error in reading it as overfilled, when in fact it isn't. Pulling the stick out and reinserting into the tube pulls oil up into the tube and when you check it it shows up on the stick above where the actual oil level is in the oil pan. There are many, many threads on this problem on this forum. Just my thoughts - makes more sense than phantom oil level changes / "mind of it's own".
Another practice I always try to follow is... Never start/run for a short period of time (like moving into the garage after washing). If I let it sit all night after doing that, I had a good chance of getting the rattle. I think it has something to do with the tensioner not getting fully pumped up during the short run period and then being very slack for the next morning start. I always take it for a bit of spin if I need to do a quick move.
But as everyone said.... watch the oil level.
09R56
11-16-2022 10:49 AM
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
10-24-2018 01:20 AM
