R56 Liqui Moly
Old 06-18-2013, 02:54 PM
jordan.burks's Avatar
jordan.burks
jordan.burks is offline
Liqui Moly
Has anyone heard of or used this oil? and if so is it a good choice to use in my mini? i have a 07 r56 MCS. the local shop i take my car to changes oil with this for 50$ and they say it is one of the best oils to use. they said its from germany and designed for german cars. they are a good shop and have done good work for me in the past and i trust them but i had never heard of this oil. I usually change my own oil with redline 5w30 and it cost me about 60$ so this could save me some money and work not having to do it myself.
Old 06-18-2013, 03:11 PM
Miniman s's Avatar
Miniman s
Miniman s is offline
I have used it before its good stuff as long as you get there better stuff I prefer the longtime high tech. When it comes to oil always ask if it has a BMW long life rating of at least 4.
Old 06-18-2013, 03:38 PM
jordan.burks
awesome ill ask them that when i get it done. they are a bmw/mini speacilst shop so im assuming the oil meets that spec but i'll verify. i just wanted to make sure the quality is good. i only go 5-6 thousand miles on a oil change so i dont abuse it but still. thank you!
Old 06-18-2013, 05:05 PM
Karl Childers Lovechild's Avatar
Karl Childers Lovechild is offline
What you want is BMW LL-01, and it'll be fine for 5-6k oci's.
Old 06-18-2013, 05:17 PM
jordan.burks
I'm just wanting to know about liqui moly right now. i already know of a bunch of oils that meet my car's spec. Im considering having my oil changed at a shop i frequent instead of doing it myself. the shop uses liqui moly, a oil that they swear by and say is excellent for my car but one that i have not heard of. So i want to know if it is in fact a good oil.
Old 06-18-2013, 05:26 PM
BMW LL-01 is the "spec" or "rating" for the oil. There is a Liqui Moly that meets that spec. You want LL-01, not LL-04.
Old 06-18-2013, 05:27 PM
mikeyb74's Avatar
mikeyb74
mikeyb74 is offline
I've run it in the past in both my BMWs and my R56. But since I no longer work for bavauto I've been using either Mobil 1 or MINI 5w30. But it's good stuff.
jordan.burks
Originally Posted by mikeyb74
I've run it in the past in both my BMWs and my R56. Good stuff.
Old 06-18-2013, 05:30 PM
jordan.burks
Sorry did you mean there is not a liqui moly that meets that spec? i was under the impression it was LL-04 for the mini's thats what the owners manual says. The shop I am refering to in this post is a bmw/mini speaclist so i can'y imagine they would use an oil that does not meet the mini spec.
Old 06-18-2013, 05:32 PM
Sorry, must be different for the Cooper S models. Didn't catch that in the original post.
Old 06-18-2013, 05:34 PM
Miniman s's Avatar
Miniman s
LL 4 is the minimum requirement and is better than LL 1.
Old 06-18-2013, 05:36 PM
jordan.burks
yeah so thats established now LL-04. Now back to people who have used Liqui moly. just want to know specifially about this oil, no spec stuff. Is this oil good or bad?
Old 06-18-2013, 05:39 PM
mikeyb74's Avatar
mikeyb74
mikeyb74 is offline
I never had any issues with it.
Old 06-18-2013, 05:45 PM
I've used the LL-01 in my Z-4, it is OK, there are better oils though. Also, LL-04 is not "better", it's different.
From BMW:
5) Longlife-04 oils are only approved for spark-ignition engines in Europe (EU plus Switzerland, Norway
and Liechtenstein). They must not be used outside this area.
LL-1 oils are for high sulfur content fuels - as in USA fuels.
LL-4 oil is for low sulfur content fuels - as in Germany/Europe fuels
Blainestang (01-22-2021)
Old 06-18-2013, 05:54 PM
You guys sure about LL-04????? I've seen nothing about using LL-04 unless it's a diesel in the U.S.
Old 06-18-2013, 05:56 PM
jcauseyfd's Avatar
jcauseyfd
jcauseyfd is offline
For the U.S. market, it is LL-01.
Old 06-18-2013, 05:58 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
according to BMW, LL-04 is NOT compatible with US gas and is not to be used
LL-01 is the correct rating for the US
scott
Old 06-18-2013, 06:08 PM
jordan.burks
okay regardless i have been using redline 5w30 since i have owned the car. im not really concered with what spec my car takes as i have been using the proper oil anyway and only planned to change that because i was considering having the shop i take my car to change my oil instead of doing it myself. I posted this thread to find out about Liqui moly oil. I just want to hear from anyone in the mini community who has used this oil and what their opinions on it were. thank you mikeyb74 as your pretty much the only one who has given my anyting on liqui moly oil instead of what spec my car takes.
I figured as much...........not that using LL-04 will cause your engine to explode, but I figured it was LL-01. I don't have an "S" so I wasn't sure if there was something special about that model with the turbo. Liqui Moly is OK. It gets the job done. The one you want is "Synthoil Longtime Plus".
Old 06-18-2013, 06:12 PM
Miniman s's Avatar
Miniman s
Nothing wrong with liqui molly LL 1 is the requirement but the dealers now carry and use LL 4 because it is a newer spec.
Only trying to be helpful, now maybe you learned something today. I said I've used it. Don't be butthurt. If you wanna know about oil, you should be on bobistheoilguy.com.
Old 06-18-2013, 06:22 PM
jordan.burks
thanks i'll check that out. i wasnt trying to be rude, i just really wanted to know about liqui moly and it seemed that the thread was going into a full on spec conversation. i went to mini.com and LL-01 is the correct spec. like i said i have always used redline 5w30 so i wasnt worried that i was using the wrong oil spec. I was just considering switching to liqui moly sine that was the oil the shop i go to uses. thank you for the help.
Old 06-18-2013, 06:28 PM
No hard feelings- the fact that it meets LL-01 tells you that it is good enough.
Old 09-24-2019, 01:24 PM
thekevlarkid's Avatar
thekevlarkid
thekevlarkid is offline
RE: Liqui Moly in my 2010 Clubman S (N14)
This probably isn't too much help, but I am a big fan of the LiquiMoly products. My mini has run it twice consecutively and I felt as though it made the car run very smoothly - moreso than the Castrol that was being put in. This was however during the period in which my mom was the cars daily driver. I did an OC prior to driving the Mini on an unplanned college adventure that led me from Indiana to Savannah, GA all the way down to Key West, back up and over to Panama City Beach for the spring break girls, then to New Orleans. From New Orleans back to Indy, with the mini fully loaded with various vacation supplies, me driving (at 6'10 235) and a friend in the pass. seat (at 6'3 185), we - well me, in my infinite wisdom - stumped upon a Lexus moving at a high rate of speed. Mini newly and temporarily equipped with the AntiLaser Priority, we ended up doing 120+ mph for every bit of 175 miles.
Being no stranger to triple digits in mom's Mini (🤦🏼*♂️ I'm a terrible person, ik) i had never felt the car run so smoothly. There were MANY different variables here's given I was way south out of the cars normal Indiana climate, but maaaaan she ran like a scolded dog.
Upon return, I'll dropped the oil and replaced it with another OC of the LiquiMoly. Mom specifically asked what I had done as she "felt it was running smoother." - Car was switched back to Castrol thanks to the local OC shop.
Mini is now mine after the parental unit tried to trade it in at 105k for a "broken flywheel". Bought it for $500, rebuilt it all. (This was 6 weeks ago) I just ordered LM to put in it when I do my OC on Friday before driving it from Indiana to Portland, OR.
That's all I have for input - my very unscientific testing of LiquiMoly. I will however report back after the drive to Portland on it's new blood.
Old 09-30-2019, 12:04 PM
ECSTuning is online now
Received 2,091 Likes on 1,865 Posts
+1 I am running moly gen LM on both my MINIs.
Quick Reply: R56 Liqui Moly
