R56 RFT and Non-RFT Mix
RFT and Non-RFT Mix
Have done a fair amount of searching, I couldn't find a similar thread. Last April I bought my wife a 2012 MCS with 14K on the clock. I did a fair amount of research on the mini prior to purchase, but was not familiar with RFT's. A couple of weeks after buying the mini, I noticed one of the tires had a nail in it. No big deal, took it to Discount Tire for a quick repair. Surprise, tire can not be repaired, about $250 later I'm back on the road. Then a week ago, I was checking the tire pressure prior to a trip to San Diego to cool off (it was 118 today here in Phoenix). Surprise, one of the tires has a bulge in the sidewall, another $250. So, now I have two new tires and two with about 15K on them, about halfway to end of life. I plan to switch completely to Non-RFT (which I probably should have already done). Can I run say the two new RFT on either the front of back and two Non-RFT? I am suspecting this is a really bad idea, I should just replace them all when the two older RFT need to be replaced. Pls be gentle, looking for advice from the more experienced.
I would agree that it is not a good idea to mix RFT and non-RFT tires. Handling characteristics could end up being somewhat unpredictable. Follow your gut instinct and replace all for at the same time. If you don't want to wait, maybe you could check with DT to see if they would give you some credit for the fairly new tires.
Why not try to sell the two new-ish runflats now (Craigslist?), and use the proceeds towards the cost of your new set of non-runflats?
I replaced my Conti runflats @ about 16K miles. I could have gotten a few thousand more, maybe - - but they were pretty well done, not much tread left. Your two old tires just might not last as long as you predict.
It might be better to sell the new ones soon, while they're still new - just a thought...
_________________________________________________
I'm in the process of replacing my runflats(205/45R17) on my MCS 2012 with non-runflats and any advice as which non-runflat to use would be appreciated. I'm also purchasing an attachment from MiniFini to add a spare tire holder to the back of the mini. As an additional note, when I purchased my mini I also purchased from discount tire a road hazard warranty for 178.00 for piece of mind.
IQRaceworks
53
06-28-2024 07:29 AM
XsV
24
09-30-2015 03:17 PM
