R56 Turbo does not boost
its been a few weeks that i feel that my car is not very well...the problem is when i try to accelerate hard the boost it comes slowly and the rpms too and i need to lift my foot of the gas and hit it again to boost correct...anyone with the same problem or any advise?
thanks..
thanks..
Apples to oranges here, but maybe I can help. My Saab 900 had this same issue. Turned out to be the direct ignition cassette. I chased everything, and even put on my other spare DICs, but the problem stayed. A brand new DIC cured the problem. Where am I going with this? Check the ignition system. Start with new plugs as they are cheap and easy, then consider your coils. Sounds like your not burning the fuel with the popping exhaust sound to me.
I had this problem occur before with my mini (07 S). Replaced the vaccuum pump and it's been fixed since then.
Also check and make sure that the tube from the air intake filter box to the turbo is tight on the turbo side. Seems to be a common problem with these slipping off on the N14s. The tube slidding off is an easy fix.
Either clean then wipe the inside of the tube with hairspray or buy a new tube for ~190$. I opted for the hairspray and mine hasn't slipped off in a few hundred miles.
