R56 Rattle in overhead console where the sunrtoof switches are
I have a 2008 MCS and the overhead console where the switches for the sunroof and overhead lights are rattles over bumps and when I knock on it with my hand and during loud music. I do NOT have a sunroof so it is not the infamous flaps needing felt issue.
When I push up on it.. the noise stops.. so this is it.
How do I remove this overhead plastic console so I can line it with stuff to keep it from rattling?
Like they said there is a cover that you can carefully pull off to acess 2 t20 or 25 torx screws. then you will have to go around the base and unlock tabs from a retaining ring that is glued to the headliner. chances are the retaining ring has come unglued from your headliner and it is causing the rattle. You can simply reglue it down and then carefully reinstall the assembly making sure you don't knock the ring back off the headliner. I like to use a small hook tool to pull down on the ring as im pushing up on the assembly to get the locking tabs in place.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
Nicefeet
09-24-2015 06:53 PM
