R56 ra2fanatic's R56S build
Old 08-11-2014, 06:06 PM
krawzdogg's Avatar
krawzdogg
krawzdogg is offline
Any chance of a side profile shot? Any rubbing at that height? I am just wondering for when I have my new coilovers set up. It would be nice to show Detroit Tuned so they have an idea when setting everything up. Thanks!
  #602
Old 08-11-2014, 06:16 PM
ra2fanatic's Avatar
ra2fanatic
ra2fanatic is offline
You'll rub when you take a hard right or left and fenders will rub on the wheels. I will have to raise it a tiny bit so I don't absolutely destroy my new set of fenders when I hit the track later this month. =P
  #603
Old 08-11-2014, 06:22 PM
krawzdogg's Avatar
krawzdogg
Ok thanks. I will probably have them set it slightly higher. Any chance more camber would fix the issue? Whats the camber now front and rear?
  #604
Old 08-11-2014, 06:27 PM
ra2fanatic's Avatar
ra2fanatic
Yes, more camber will fix rubbing on dips and stuff, but like I said, there isn't anything that would prevent it from rubbing on the front when you're making a highspeed turn.
Camber at the moment? I can't really say since I haven't gotten the alignment done. I need to dial in the suspension a bit more this coming weekend to get the right ride height, then I can get the alignment done. It'll probably be -3.1 up front and -2.x in the rear when all is said and done though.
  #605
Old 08-13-2014, 07:47 PM
'10JCW's Avatar
'10JCW
'10JCW is offline
Hey man, I have a question about where to go next with my build. Currently I have the following mods:
BattleTune Stage 3
CNT racing catless DP
Wagner FMIC
Forge Silicone inlet/hotside tubes
GFB DV+
Alta CAI
JCW stock exhaust
John mentioned an OCC, but I was wondering where you would go next? I am debating on getting an Alta front end swaybar (I am going to the Minis Slay the Dragon in Oct), save up for exhaust, or get some new spark plugs. Thoughts?
  #606
Old 08-13-2014, 08:51 PM
RJT's Avatar
RJT
RJT is offline
BattleTune Stage 3
Wagner FMIC
GFB DV+
Alta CAI
JCW stock exhaust
my two cents......you want your car to rotate, not understeer, need to up the rear sway, if you haven't already, and get an aggressive alignment...stay away from front sways...do you have camber plates and coilovers? This will be the most notable and the biggest effect on our cars driving dynamics. Throw on some sticky tires and get on it! A step cooler on your plugs always helps with pre-detonation if you are having this sans a water methanol squirter...
  #607
Old 08-14-2014, 08:39 AM
ra2fanatic's Avatar
ra2fanatic
^+1
If you do intend to do anything to the front, it's reducing the size of the sway bar to the non-S bar. It's 1mm smaller in diameter but I'd only recommend doing that if you knew how to do it yourself or if you had the whole engine out.
Exhaust would be a good option to go with since you have the factory JCW system for now. Other than that you're pretty set on Stg3. Other things you can add, which are miscellaneous, non-power-producing items like shifters, wheels and stuff like that.
  #608
Old 08-15-2014, 10:07 PM
redparchel's Avatar
redparchel
redparchel is offline
How is this done on the r56 ohlins? is this done by adjusting the preload on the shock? and if so does that have an effect on the 'rate' (for lack of knowing a better word) of the spring?
  #609
Old 08-22-2014, 07:41 PM
ra2fanatic's Avatar
ra2fanatic
  #610
Old 08-22-2014, 08:37 PM
RJT's Avatar
RJT
RJT is offline
Looking badasssssss! Want that challenge wing, just about ready to neuter my car, bummed by kind of excited to see what I end up with next. Have a great weekend Friend!
  #611
Old 08-22-2014, 08:44 PM
ra2fanatic's Avatar
ra2fanatic
Likewise! Have a great weekend. I dropped off the stuff at Ivan's so they're there when you need them!
  #612
Old 08-23-2014, 05:30 AM
MinMin2010's Avatar
MinMin2010
MinMin2010 is offline
RJT, if you really want one, I have my old one for sale. It is the M7 carbon fiber model for the R56. Just e-mail me if you are interested.
reaja@***.net
  #613
Old 08-23-2014, 11:31 AM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Subscribed.
Haven't had a chance yet though to read the whole set so sorry if already asked. I saw at least initially you've used 3 FMICs and 2 intakes so far (at least). Notice any pros/cons between them?
  #614
Old 08-23-2014, 12:07 PM
ridinDirty's Avatar
ridinDirty
ridinDirty is offline
MinMin2010, I sent you and email if you still have your M7 wing. Is it the full carbon ?
  #615
Old 08-23-2014, 02:24 PM
ra2fanatic's Avatar
ra2fanatic
Originally Posted by Aelwulf
Subscribed.
The Evolve unit was the least favorite. It didn't have a solid build, that's just my personal opinion. The Helix is great, but the Wagner has been the best so far. It's stealth black and doesn't pop out through the grills, but that really doesn't bother me too much. Black is known to have better heat reduction.
As for intakes. I really first had a DDM Street. Didn't like it because it couldn't clear my M7 strut tower brace at the time. Then we to DOS and it was great, but the sound it made got old fast and just started to annoy me. Claimed to be a "true" CAI, I mean, I guess it was, but I didn't feel much difference. Went to AEM and it was great great system. Melted a valve cover of mine, which was a bit of a mess, but I still to this day feel it's a fabulous intake. I parted ways with it to go with the JCW cone intake and put a new Amsoil cone intake on it. Why? Because the AEM intake piping would not fit on the diameter of the upgraded turbo I had and it just became a pain popping open the hood to ensure it was still clamped on there. So I said screw that and went with the JCW hardpipe along with the cone JCW intake. Fits perfectly fine and I have no issues with fitment onto the turbo anymore.
Hope this was informative!
  #616
Old 08-23-2014, 02:31 PM
ra2fanatic's Avatar
ra2fanatic
Today, mounted the track wheels. Haven't put on the Volk Stickers on the spokes, but I think I really and genuinely like these wheels the most after all the different set of Volks I've had up to this point.
Height was raised a bit, and now the ride is much nicer. I think it was so low before it was hitting the internal bumpstops, so now....now this is good
  #617
Old 08-23-2014, 02:59 PM
HardTop09's Avatar
HardTop09
HardTop09 is offline
Sweet ride...
  #618
Old 08-23-2014, 03:35 PM
R56BrgMcs's Avatar
R56BrgMcs
R56BrgMcs is offline
Those are such cool wheels. The look right at home on your MINI. I've wanted a set for every car I've had. Only four cars but still, I've wanted to put them on each one.
  #619
Old 08-23-2014, 04:07 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Curious, what height are you at? Could you measure from the ground to the top of the wheel arch?
  #620
Old 08-23-2014, 06:00 PM
ra2fanatic's Avatar
ra2fanatic
Top or the bottom? I'll tape measure it later today.
  #621
Old 08-23-2014, 06:03 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
The bottom of the arch. Thanks!
  #622
Old 08-24-2014, 06:45 AM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Quite, thanks! I originally discarded the AEM a bit out of hand because I know it's a large brand and figured they just did mass production at a lower price for the masses who wanted to look cool. But from what I've heard on here it does seem to be a good intake. I like the straight-from-scoop setup and that it comes with a turbo shield (from what I've seen so far), and they make a bar to go over it. But I'm leaning more towards the JCW one myself. It doesn't seem to look spiffy per se but it does keep things a bit more JCW overall and seems popular for performance. Plus it being fairly low-key on design should open up options for tower braces. I kind of like the M7 myself (if it's the one with the 3 shaped holes toward each end I'm thinking of) but haven't gotten to really looking into them yet.
The FMIC bit helps a lot. I was rather considering the Evolve as I'd like a black one just from the appearance perspective but it seems other than Forge it's been iffy on a good FMIC on here. I haven't seen/heard much on the Helix before now other than occasional side mentions and sigs. I'll have to check out the Wagner. How's that one fit-wise, have to cut plastic or anything or is it a straight fit?
Edit: I just came across a thread of mine where Grizld700 gave me some input on the Wagner. Still interested in yours though. Not enough sleep makes one something something...
  #623
Old 08-24-2014, 06:34 PM
ra2fanatic's Avatar
ra2fanatic
Fronts: 24 1/8"
Rears: 24 1/4"
  #624
Old 08-24-2014, 06:38 PM
ra2fanatic's Avatar
ra2fanatic
The Wagner intercooler is not a straight fit. Just like the Forge unit, it has a top mounted tab. I cut the tab off because you don't need it and with it, you wouldn't be able to fit the unit flush/parallel to the condenser unit.
To mount it, cut the top tab, and then the upper portion should slide up in place before the bottom. Line up the bottom and then connect the 2 hoses. Pretty easy once you've cut the tab.
  #625
Old 08-25-2014, 05:37 AM
Aelwulf's Avatar
Aelwulf
Aelwulf is offline
Shiny, thanks for the input!
Quick Reply: R56 ra2fanatic's R56S build
