R56 ra2fanatic's R56S build
#201
#204
#206
Gotta remove the downpipe so we can coat that as well.
suhweeeeet!!!
#207
on
I have the fJCW Brembo's now, will be installing TCE/Wilwood setup so I can run 275/35/15s this year.
I think Bster13 is doing the Brakeman setup so if we all can compare notes in 6 months we can decide a winner. Better yet we all meet up some where
#208
Geez, what's the purpose of running 15s??? 275!?!?!?
#209
on
15's = Lower rotating mass, and less unsprung weight in most cases. Both of which make for a faster car in cornering, accelerating, and yep even BRAKING.
Just because you have massive brakes does not mean your braking will be better than a properly built and set up brake system that can fit in a small wheel. Look at F1 cars... 200+ MPH, tiny little brakes.
The Brake Man kits will easily out perform any of the big brake kits offered for MINI's. They also use a very solid caliper that will not flex like the Willwood, Brembo, Stoptech, and the others. The pads are easily available from multiple vendors, and are not only cheaper, but have longer life than the ones used in the BBK's.
Though they are not the cheapest option, you can see why my 13" Willwood's are coming off, and Brake Man's will be going on. Also going to be using a 15" wheel... 15X8 With a 225 wide NT-01 in the front! Less weight than the 17's and more STICK!
#210
I never said my massive brakes were going to be better brake system. Hence why I left that as subjective as possible. And I figured 15s would understandably equate to less rotating mass.
I'm more than happy with my 17inch, 14lb forge wheels and would never go any lower than that, that's just my opinion. And these brakes don't flex and one of the stiffest calipers on the market that aren't complete race kits. With a full-floating rotor it helps with pad knockback also.
#212
#213
#214
#215
My 1980 Daston 200SX had fuel injection (eight spark plugs, 2 per cylinder) and four wheel disc brakes, the rear calipers could only be twisted in like the piston had threads. My only guess why there are like that has something to do with the E-bake. The StopTech Trophy big brake kit is growing on, I have always loved satin silver colored calipers!
#216
What would be really nice is if someone made a rear kit that didn't involve jumping through hoops just to make the e-brake cables work with the new caliper. Simply undo the cable, and swap it to the new bracket on the new caliper. None of this re-routing crap or extending the cable.
#219
on
John, being that Wilwood is in Camarillo, just down the road from NM, you might check with them to see of they can do the same finish on a rear set like you have on your new STOPTECHs. You could ask them if they can leave the Wilwood logo off. BTW, I really like my Wilwoods. Jerry got me a great deal on them.
#220
#221
#222
#223
Looks like a perfect fit, nice! As I understand it the StopTech offers in a few different rotor diameters, what size did you purchase? Also what's the going rate for this ceramic coating?
#224
#225
JM Turbo is doing all my ceramic coating. You'll have to ask them about their prices.
It would be a bad idea for me to be tracking after all this work. I don't want to be mashing on everything w/o properly breaking it in.
