R56 Camber Plates Question
on
I am still very new to the Mini...I have only owned my 2008 MCS for two weeks. I did a search for this and didn't really find anything other than recomendations to put on camber plates if you needed adjustment for the track...which I do. This past weekend I did springs and adjustable Camber Plates...question is this:
Are they a little louder, kinda clunky sounding? Not really loud, just barely noticeable if the radio is off. We got the struts tightened down just to the point that the camber plate mounting head could be rotated to get it into place, any tighter and it would not move...so we know that is tight.
Just curious if that is normal. I know on my RX-8 when I went to coilovers there was a very similar sound in the rears that was considered normal and part of the deal...
Thanks for any advice...
on
My H&R camber plates have always made a little more noise and added a little NVH to the car when compared to the OEM top mount. The camber plates replaced rubber parts with metal plates/bushings/bearings so I would expect a little extra noise/feel.
However, if a louder clunk your top strut nut might not be tight and thus allowing the spring to move a little too much in the perch.
Also, I notice a little extra noise/feel when the top bearings need to be cleaned and lubed. The bearings tend to start binding up after a year or so and need a little TLC.
on
on
on
nylon lock nut is one other thing I considered...but I really don't want to take it all apart again, and jack up my new alignment...I can only assume that it is not safe to remove that nut while the strut/spring assembly is still on the car.
How are you planning to add Loctite without removing the nut or getting it backed off enough to get Loctite on the nut or strut threads (under the nut)? Just adding Loctite to the top of the nut at the strut threads will not be adequate because the Loctite needs to be on the strut and nut threads where they thread together and where the air gap is eliminated to the Loctite to adhere/cure properly. Also remember to let the Loctite cure for the proper amount of time based on the air temperature.
on
That might work. I would put the Loctite around the top, then just back it off a few threads, add more Loctite and tighten back down. We do not want to back off very many threads because you want to keep the initial Loctite application in the threads where the nut will stop again when tightened down. The key is not to lose/wipe all the Loctite onto strut threads where the nut will not even be when tightened down.
If you can get to the top nut with the suspension still on the car you could take the top nut off. It's not going to go anywhere. Just make sure the suspension is at least lightly loaded so the strut doesn't fall out of the bottom of the camber plate.
Camber plates make noise. Usually slight noises but my Vorshlag plates aren't exactly quiet. The IE plates should be much less noisy since they're not solid metal like the Vorshlag plates.
on
on
If there are enough threads coming through the nut, you can also run a second nut down onto it. Hold the one with one wrench, tighten the new nut against it with a second wrench. That's "double-nutting" or adding a "jam nut". If that doesn't hold, something is really seriously wrong...
Is the original nut a locking nut? Does it have a plastic insert (e.g., Nyloc nut) or is it deformed? Does the threaded part have a slot in it that would normally fit a tab on the inside of the washer?
One of my previous cars had that last setup. You folded up the edge of the washer along one of the flats of the nut, and that held it in place.
on
Minibeagle
08-13-2015 10:00 AM
ClayTaylorNC
08-10-2015 09:19 PM
