R56 has anyone had to replace thier vacuum pump?
I finally got tired of the crappy performance and gas milage so I took off the intake manifold and scubbed all the goo from the intake valves but while I was leaning on the engine I broke off the little plastic thing that bolts on top of the vacuum pump that hooks to a hose that feeds into the brake booster. I went to the local dealer and they said they can only sell it as one piece and refused to let me buy just the piece I needed. The whole thing is 500 bux.... has anyone on here had to swap out thier pump cause all I need is that plastic piece. il give you some money for it I just cant find anyone who will sell it separately.
Yea, the top neck it not a separate part. If you cannot find one used or one that is complete we have some options below.
Vacuum Pump Part #11667556919 N14 engines
http://www.ecstuning.com/Search/SiteSearch/11667556919/
Vacuum Pump Part #11667586424 N18 engines
http://www.ecstuning.com/Search/SiteSearch/11667586424/
Thanks and good luck.
One is Genuine MINI and one is from Pierburg direct.
marendt428
11-14-2015 10:03 AM
durablack
R55 :: Clubman Talk (2008+)
10-05-2015 01:51 PM
marendt428
08-08-2015 04:44 AM
