R56 Lug Key
Lug Key
So a buddy and I were doing my rotors and pads. Whoever last tightened the lugs on the back wheels went pretty heavy on them and when were trying to take the key lug off the entire top of my key sheered off.
What exactly can I do at this point? Does the dealer sell them or is there some other way I can get these off without a tap and die?
If they're universal for Mini, which mine are factory, anyone in south jersey want to let me borrow theirs? Lol
A little update.
I'm taking the car up to Pep Boys tomorrow to get all 4 tap and died. Just going to put on 4 after market lug locks instead. It makes me kind of cringe to bring it to them but, I don't really have a choice right now. 2 of the lugs are loosened on the front, not torqued and I can't torque them so, I can't really wait a week.
Pep Boys is the closest to me and they said they'll tap and die all 4 for 50 bucks so, that's not too awful. Going to continue my brakes tomorrow myself, which stinks buts, need to get them on there.
Take a socket that is just a little too small for the outside of the lock. Put it over the lock, then hit the snot out of it with a BFH. (Thst' short for Big Hammer.) It should go on. Then you can plug a breaker bar into the socket and loosen the lock.
I don't bother with wheel locks, myself; I've had some close calls and have decided that it isn't worth it to use them.
This is just the icing on the cake. So you mean just push a socket onto them and I should be able to get them off using like a torque wrench or something?
If it works, it'd be great to save 50 bucks, lol.
Honestly, I'm thinking of just buying a lug set and throwing them onto the car. The wheel locks have been quite annoying with shops forgetting to get them back to me and me forgetting them when I take it to a shop. This is just the icing on the cake. So you mean just push a socket onto them and I should be able to get them off using like a torque wrench or something? If it works, it'd be great to save 50 bucks, lol.
Never use a TW to loosen fasteners.
I was actually using a breaker bar when trying to remove the back ones, lol. Well I'm going to try this tomorrow. If I can't manage to get it to work, I'll just go get them off with a tap and die.
Use an impact socket. The standard ones can shatter. Also if you have a pipe, slip it over the breaker bar for more leverage. I have a 6 ft pipe for my 2 foot bar. Also vibrations can help. While holding a torque on the bolt, tap the breaker bar with a hammer to loosen.
newminijcw
10-21-2015 02:37 PM
