R56 Mods on an automatic?
I recently inherited a very nice 2007 Mini Cooper S, with an automatic transmission. Currently the only mod is a sprint booster.
I feel like the car could use some more power, but am unsure how far I can go with the automatic and am looking for some advice. Should I not do some mods because of having the automatic?
Here are what I'd like to do (and I'm unsure of which model of each part): intake, intercooler, hard pipes, tune, turbo back exhaust.
I've seen that there are some transmission cooler kits offered. Should I install one of those? Are there any shift kits available? I understand that the automatic will probably wear out faster than a manual transmission, but I would like it to at least last another 50k miles before needing rebuild if that's possible.
You can do with an automatic nearly everything you'd do with a manual. You won't need a short shift kit. ; ) And aside from that, I can't think of anything you can't do. I think most people though will look at handling upgrade first though. Shocks, lowering springs and larger rear sway bar. It really depends on where you want to spend your money, and it can take plenty!
Also, I do plan on doing handling+braking mods, I just figured I wouldn't list those as they don't have anything to do with the strain on the transmission. I'm planning on Koni Yellows and a set of Azenis RT-615K tires and some nice Hawk brake pads. I'm not sure that I feel that it needs a sway bar upgrade for street use.
Is the car in your sig an automatic? It's held up fine with no signs of slippage? Have you installed a transmission cooler?
One thing that wouldn't hurt is change your transmission fluid out to a synthetic type. If you haven't done already.. Synthetics hold up much better anyways. Also IMO the transmission shifts much better.. Im not even sure one could add an external cooler on these type of transmissions anyways.. So the next best thing would be a good performance grade synthetic ATF. Good luck!
Yes, you can install an external transmission cooler using this part: http://new.minimania.com/part/G2NMD5...0-61-Cooper--S
Thanks for the tip on the synthetic, do you have experience with a particular brand in your mini?
As above change your atf first that's what I did before flashing my auto with a stage 3 Evolve tune and have had no problems and that's with driving it hard smoking up the tyres coming out of turns and doing multiple 0-100km runs to check the progress of engine mods.
That's what I'm talking about! Love it! Good to hear that there are a few guys out there modifying their automatic Minis.
Vendor
We've modded many Automatics without any issues. The car can handle all the bolt ons without issue. And if it makes you feel better the new MINI JCW with the Automatic uses the same trans without any mods to it and they don't break. Feel free to call us for advise or suggestions.
Rear sway bar seems to be popular.
Shocks and tires would greatly help and it is good to have powerful brakes
I did 4 drain/refills for a total of 8 litres of fresh fluid through the trans and will change 2 litres every oil change/10km to extend the life as much as possible with the power I'm running. You also have to remember the ECU limits torque in the first two gears to protect the trans and I'm guessing to avoid wheel spin.
If that was a reference to my post, I actually did my first change at 100,000km the car was second hand. So don't stress there after ever 10k, I take BMW life time fluid claim as meaning until warranty runs out.
http://www.passatworld.com/forums/91...ilter-diy.html
https://www.northamericanmotoring.co...rain-fill.html
https://www.northamericanmotoring.co...ion-fluid.html
I did mine at 10k as 'preventative' maintenance since there are no oil coolers to speak of on this motor, and the coolant temp runs high, and there is a turbocharger strapped to the front of it. In retrospect, I could've waited maybe to 15k so drain/fill 2-3 quarts of synthetic every 15-20k and you should be plenty good as the whole system is 6-7 quarts or so. I wouldn't run the factory non-synthetic past 50k so this should flush most of it out by then (3-4 drain/fills).
Royal purple seems to work for me
yesti, I was just curious when you changed your ATF at around 10k how did the fluid look to you? I think changing it early is also a good idea. I myself wouldn't use nothing but synthetic in these type of transmissions. Changing it like you do is a very good proactive way to do it..Many wait till the transmission starts to act up.. But by then its very likely damage has been done to the tranny already. There are a lot of good ATF fluids out there.. Im a amsoil junkie lol
To be honest, the fluid looked fine (as to be expected at 10k). That leads me to plan on drain/filling every ~15k miles at the earliest since it isn't the cleanest, quickest fluid change job . That being said, I did feel the (possible placebo) effect of changing out 33% of the fluid on the drive home . I've never used synthetic fluid before so I picked Royal Purple on amazon. Amsoil is great stuff too I've heard.
Lots of great fluid choices out there. Picked Royal Purple Max-ATF full synthetic that complied with the spec. Did three drain/fills 2.3 qts each at 50K miles...what a time consuming PITA. But definitely worth it. First drain looked like burnt coffee. "Life time fluid my @ss BMW." Transmission shifts beautifully and just feels tight now.
FWIW I've spoken to two different very respected tuners in Florida who have tuned R56 auto's to the 240-250 whp range with no problems.
Thanks for the tip about the transmission capacity. Would you happen to know the torque figures on those cars?
