R56 Oil Catch Can???
Oil Catch Can???
Hi Everybody,
So, Ive been hearing a good bit about "Oil Catch Cans" i get what they do, but would anyone recommend them? Are they useful? especially for the R56's because of their oil consumption i thought it'd be a good investment. If you guys can fill me in and give me some info on them and the installation process, cost,good ones to buy, info about them..etc... That'd be much appreciated!
Thanks!!
Thanks!!
You can use an OCC to 'catch' vapors from your PCV system before reentering your intake just before the turbo and just before the intake manifold. I have an OCC on my driver' side and have NOT blocked the passenger side. An OCC costs a little money, and in my eyes, can't hurt if you are emptying it when you change oil. Blocking off the passenger side causes the vapors to go through your OCC during not only boost, but also vacuum. I am not convinced it's a good idea to block after reading through the threads about oil consumption via an internal oil leak some report.
What brand are you interested in? I have the BSH from WMW.
~stay mini~
I have a BSH Oil Catch Can with the passenger side PCV hose blocked off. My MINI barely consumes any oil.
The main purpose for an OIL Catch Can is to reduce carbon build up on the intake valves on the direct injected N14 engined Cooper S. The non-S cars have port injection and don't have a carbon build up problem. N18 engines, 2011 and later, also don't need an Oil Catch Can, as they have an improved head design that reduces intake valve carbon build up.
Dave
Dave
Maybe I have a good mini lol. Mine never consumed oil and I'm only able to empty my occ once every one month in the winter and 6 months in warm weather. Even when I empty it it's never more than 25% full. I'm willing to sell my occ if anyone wants it (OP?) I'll include the PVC blockers too (brand new never uses)
It can't hurt, but definitely do your research first. There are a lot of threads on here about it. Read the ones about reported increased oil consumption after blocking the passenger side PCV in particular. Could be idiots forgetting to empty their OCCs until they overflow OR could be a pressure issue in the PCV system when blocked off that causes oil to be redirected into the combustion track at some point. I don't know, and I'm not going to risk it, so I don't have it blocked, but I also drive a LOT of highway so my engine is less likely to get carbon than a 5 minute around town driver.
Even with an OCC, if you are not driving extensive highway miles, plan on having a carbon cleaning every 30-50K. Lots of threads on here about DIY methods with plenty of pictures of carbon buildup, or you can pay someone $500-$300 to do it for you.
Stand on the shoulders of giants... I have an OCC, but am basing most of my opinion on what others have said alongside their photos.
FWIW, I have been researching catch cans for my VW and even had my PCV setup for VTA (vent to atomosphere). I thought this would reduce buildup on the valves and manifold, but the truth is 2 years later it's made little to no difference. Just made the car smell a bit. Direct injection is dirty by design, your best bet is just a manual cleaning some time. I'd say 60k-80k if it's running ok.
cristo (02-13-2020)
Supposedly, you can drive the car hard (above 3000rpm for 20-30min) and it will burn off most deposits. The 'Italian tune-up.' That said, a manual cleaning involves removing the intake manifold. I would say it's more tedious than hard. Here is one thread
https://www.northamericanmotoring.co...-cleaning.html
I have a BSH OCC and PCV Block that I installed after I had the walnut blast 15K miles ago...I used to burn about a quart every 5K miles (I change oil every 5K) but over the last 3 oil changes I use less than 1/4 quart/5K. I just changed oil this past week and pulled the intake off and used a lighted bore scope to take a peek at the valves...no buildup to speak of. When I did the walnut blast at 38K it was absolutely horrible! Big chunks of carbon buildup...I was surprised the valves even closed!
So...in my book the OCC and block is worth every penny....but I'll pull the intake again in 15K to take another peek.
Sounds like everyone is saying, 'Here's my opinion, but I don't rightly know for sure.' Socal will 'know' after he pulls his intake, but I'd say block at your own risk, and don't forget to empty the thing. =)
Well Ian, I'm not really sure what an OCC is, I've never owned a turbo'd car before, nor one that uses so much oil. I knw that the R56's burn a good amount of oil, thats why i was looking into the oil catch can. Other than that, I'm pretty unsure, so when you refer to an OCC I'm still unsure on what you mean, obviously its something that will catch oil vapors or something along the lines of a PCV valve. And as far as brands go..im just as clueless, thanks for the response and i look forward to hearing from you. ~stay mini~
molala
10-02-2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
