R56 Reduced engine power + abnormal engine noise
02-28-2014, 02:53 PM
on
Mini was warmed up and driving normally for 5 mins.
Stepped on gas, 50% reduced power, engine sounds terrible!
Yellow check engine light.
HELP!
02-28-2014, 03:21 PM
Get the code read. Then come back for help.
02-28-2014, 05:25 PM
on
P0301 cylinder #1 misfire (bad ignition coil)
According to Autozone scanner, should I buy it?
02-28-2014, 05:30 PM
Quote:
Originally Posted by
r56cooper
Not yet. Swap coils around first and see if the problem follows to the new cylinder or stays on cylinder #1.
03-01-2014, 04:40 AM
on
Yea it was cylinder 1 coil. Bought Duralast ignition coil pack and replaced.
Worked! Code went away immediately, engine was running fine like normal
$80 part, 5 mins, back to normal :D
03-01-2014, 04:50 AM
rob&JCW
02-13-2023 07:03 PM
07-16-2020 12:54 PM
theblackfalcon
10-11-2015 09:49 AM
minipopkart
08-13-2015 05:22 AM
Ambient Thermal Management
08-07-2015 12:27 PM
