R56 Covered Maintenance visit coincidental Limp Mode
Was Planning to take my mini in to get the "covered" oil change @ a 10k interval (I do a change @ 5k interval out of pocket). Coincidentally, days prior to my appointment, my mini went into limp mode...I was like, wtf!? I got to a destination (son's baseball practice), it sat for 2 hrs. Upon firing up to leave, it threw up the half yellow engine light again, so I proceeded to baby it, but once I got out of the parking lot, it disappears and the ride home is normal
Take it to my scheduled appt. a couple of days later and of course, it does not happen on the way to the dealer, go figure. Long story short, the High Pressure Fuel Pump and it's assembly were replaced, An oil leak @ the Oil Pump Solenoid was found and replaced (along with the assoc. wire harness), a Brake Pad Correction procedure was performed, new wiper blades, and a new rear hatch handle/switch was also replaced.
I'm glad I bought my mini with low mileage (14k)....It now has 20k. I hope all the bugs come out while I still have warranty coverage....whew!
I just took my wife's '12 MCS in for a CEL and limp mode. The SA said, probably the HPFP. They pulled codes, replaced the exhaust side VANOS solenoid instead. Had the exact same leak as yours, oil pump solenoid, replaced along with wire harness. Was told if out of warranty, cost would be almost $2k. Got a year and half of warranty left, not sure I'll keep it past then.
Can you think of any other bug(s) coming down the pike? This mini had it's chain tensioner replaced before I bought it (so says carfax). I love driving it, unafraid to throw it around and put it thru it's paces. I'd hate to give it up, but I don't want to have any major issues post warranty and my fun time window may be starting to close as miles go up and resale value goes down.
I'm at 33k and nothing serious after those. Rear sway bar links go bad, needed to replace one, did it myself, took 20 minutes.
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
