R56 Gopro Camera Tow Hook Mount?
anyone tried this?
I'm tired of my camera knocking over cones on the track 2 sec a cone
Overpriced, yeah probably, but I got it after watching someone's GoPro suction mount decide to come loose while on a drive. The camera survived but the case and mount didn't and it took a while to find it. The mount is well made and gives an interesting perspective since it's positioned low on the front or rear bumper. It screws into the tow hook mount so hitting cones shouldn't be an issue. The location also helps in picking up the engine audio.
on
I have the suction mount...
It keeps knocking over cones
http://youtu.be/4ILaZf-WkVw
How sturdy is is mounted to the front bumper...I don't want to end up running it over..
Instead of buying the tow hook mount you could use the suction cup on your front bumper too
That's what I ended up doing. right below the mirror. I'm nervous about the front bumper and it popping off. where are y'all putting it on the front?
on
1 Post
There's no doubt that you won't have to worry about it with a tow hook mount. I have the CravenSpeed and it's simple and solid. The camera doesn't tighten down as firmly as the plastic GoPro mounts for the simple reason that the mount is made of metal and doesn't "squeeze" tight. But it never moved in all the times I've used it.
I trust the suction cup on a clean, flat surface. I dumped mine two weeks ago - my own doing since I didn't clean up the side window. Wifi backpack, housing and suction cup mount were all toast, but the camera lived. Sadly, it won't recognize my new Wifi backpack, but it does work manually. A lot of good that will do when it's outside of the car.
Video
Depends on how much video you want to record?
I have Dash Cams in my car front and rear HD. Checkout www.blackvue.com and www.blackboxmycar.com They work well. Download via built in Wifi to iTouch or other device in seconds. Nice App. Simple and even works in parking mode. Nice video no hassle. Card determines how much video of course.
Got the dual unit, one behind the mirror and one in the rear. No cones knocked over!
I placed mine on my bumper with no issues for a full 20min session and it didn't come off. I don't think you'll have that issue...
R56 iPE Innotech MINI Cooper S GoPro Front Bumper Mount on Vimeo
09-11-2015 01:15 PM
