R56 Trunk grab handle switch dead
Ok, first real problem...
The trunk will not open if I try to use the grab handle.
Yes, I have comfort access, and the doors all work. The key fob will pop the trunk, so I assume that the grab handle switch is bad.
My question is, is there a cheaper fix than buying a new $210 grab handle?
I removed the handle and can't figure out how to open it up without destroying it..
Rich
Rich
Common problem!You must little bit destroying it,just twist the screwdriver or something a suitable tool between the body and backcover.Mine cover came off really easily and to reveal the micro-switch which was not fit properly.A small drop of glue to the frame of switch and gasketglue keeps cover back to handleframe. It`s very easy job! In Finland is really weird pricing, unpainted is expensive than chrome version!And carbon fiber is almost three times more expensive...
Interior/Exterior Must see: Liberty Walk body kit for Mini Cooper R56
carid
09-02-2021 07:22 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
