R56 Coolant
Coolant
Hey guys I have a 09 fjcw and lately when it's raining and cold, I can see steam/condensation coming from the hood and a hot smell but no light comes on. Today I checked my coolant level and its about an inch below the "min" mark. I want to top it off to the "min" mark so when it gets hot, I'm assuming the level will go up. The local mini dealership parts department is closed until monday. Could I just top it off with water? I have a car meet tomorrow that's about 10 miles away and wanted to top it off before driving.
Look on the top of the transmission under the intake tubes. If the thermostat is starting to leak, the coolant will pool on top of the trans and may not go down to the ground. See if there is any blue liquid or blue staining.
I also had a crack on the bottom of my coolant tank that never showed up as a spot on the ground. You can remove the screw that mounts the tank to the radiator support and look at the bottom of the tank. look for any dried coolant, or signs of a crack.
Unfortunately, 4 years is enough for your car to be developing a leak in one of the common areas (thermostat and water pump). Normally the water pump leak leaves drops on the ground.
Have fun,
Mike
Have fun,
Mike
Steffen.Johnson
42
01-25-2023 02:47 PM
