R56 Rattle/creaking noise coming from rear passenger side
Hi all. I have a 2009 R56 Cooper S with factory sport suspension. I recently noticed a rattling/creaking noise that I think is coming from the rear passenger side. I started noticing it after I downshifted one time for slowing traffic and accidentally dumped the clutch pedal as I thought it was already engaged.
The noise is like a rattling of glass or body creaking noise that happens when the rear goes over bumps, at high and low speeds. I can also hear it upon alternating hard acceleration and hard braking. I can definitely hear it upon going onto a ramp that lifts the front driver side (shifting the weight to the rear passenger corner).
I'm not sure if it's coming from the interior of the car or exterior. It sounds like interior, but I've cleared out everything from my car, secured the rear seats, and I still hear it. It's definitely not the rear sway bar end links, as I can recognize the knocking sound that comes from it. From what I've read, it could be rear sway bar bushings or loose exhaust.
Has anybody else experienced something like this? Any input would be greatly appreciated. Thanks.
Rob called it. The OEM end links are garbage, and make a ton of noise when they fail. Be careful which aftermarket links you buy though, some do not have long enough studs.
iamcamkeenan
08-10-2015 03:31 PM
