R56 Hotchkis Rear Swaybar Noise
Old 05-27-2014 | 04:20 PM
DOtheDEW's Avatar
DOtheDEW
Originally Posted by afadeev
Rear sub-frame to chassis M12 bolts: 74 ft-lbs
Sway bar link bracket M8 bolts: 14 ft-lbs
Sway bar link to bar or strut M10 nut: 41 ft-lbs
Stiffest setting is with the sway bar link attached closest to the sway bar (minimum leverage).
a
thank you! so the noise happens only under 30mph, on uneven roads
  #27
Old 06-09-2014 | 01:08 PM
MikewithaMini's Avatar
MikewithaMini
I think I have the same noise as you recently develop. I don't believe I have any interference. Going for links....
  #28
Old 06-09-2014 | 01:44 PM
DOtheDEW's Avatar
DOtheDEW
That's my next "investment", I'll be looking into some links also
  #29
Old 06-16-2014 | 11:44 AM
MikewithaMini
Well OK, I'm an idiot. Too much rock n roll as a youth.... I went and bought a new link. I had disconnected the top end of the old one and I couldn't get any play out of it with my hands but the ***** were loose and so I figured what the heck. Got one at the dealer as it was the cheapest, quickest option. Before I put it on, I dropped the shock out to assure that it was tight and gave it a blast with the impact to make sure. You guessed it! Noise was still there. I knew of the possibility and thought that I had it secured but my clunking was the rear seat belt male end knocking against the pillar. Rotated by tires and all is good except... the TPMS light went on and it won't reset. The option doesn't exist. Where it should say reset, it is blank. When you hold the button it brings up CC-ID 142. I've seen 4 mentions of it by searching but no remedy. I'm sure I'm just not holding my mouth right. Tires are within .5 lb of each other @38 psi. Any ideas?
  #30
Old 06-16-2014 | 03:39 PM
danjreed's Avatar
danjreed
You tried resetting with the car not moving (but on?) correct?
Are the tires too "hot"? I know TPMS can detect internal tire temps... Just taking a guess.
  #31
Old 06-16-2014 | 05:44 PM
OneBlackMini's Avatar
OneBlackMini
Mine seems to clunk as well, did you have any luck fixing this?
  #32
Old 06-16-2014 | 06:44 PM
MikewithaMini
Dan - Must have been tire temp as you suggested. Drove a couple miles, shut it off for the afternoon. We I came back I went back to the reset procedure, reset was there now and voila! No more TPMS warning!
  #33
Old 08-18-2014 | 05:23 PM
DOtheDEW's Avatar
DOtheDEW
if anyone was wondering, the noise was the sway bar links. they decided to give out right when i installed the sway bar. swapped the links for some new oem ones and no noise. hope that helps anyone that has a clunking noise
joedotmac (06-02-2024)
Melvinyip
04-17-2020 09:28 AM
Spank
11
04-09-2020 02:23 PM
woodstudio
03-15-2020 08:28 AM
Ryephile
Suspension
113
02-09-2020 03:43 PM
tag1260
08-05-2015 04:27 AM
Quick Reply: R56 Hotchkis Rear Swaybar Noise
