R56 any way for dealer or MINI USA to cover tensioner?
So I've read through many pages of the supposed tensioner recall thread, and is the jist of it that mini most often will NOT pay for any tensioner related repair out of warranty? I checked to see if my car has any active recalls and of course it doesn't list any. I had my tensioner replaced under warranty about 3 months after getting the car but that was almost 3 years ago...and it's long out of warranty and I'm starting to think it might be getting bad again, though I could be imagining it. I plan on checking the slack in the chain upon pulling off and replacing the cracked valve cover i currently have, is there a particular way to get an accurate measurement of chain slack? what else should I look for while the valve cover is off? Thanks for all the help, in case it wasn't clear I have an 07 mini cooper S, manual trans, and it has about 92k miles on it, recently walnut blasted, oil changes every 5k with the euro spec synthetic (i forget the rating, a3/b3?).
Bad news, because it was already fixed under the warranty Mini will refuse to lift a finger to help you, but you could tell Mini USA that they replaced an already defective tensioner with another defective tensioner. More often than not if there's a need for a tensioner replacement then the timing chain has already been stretched and it will only be a matter of time before the timing chain needs replacement. You're lucky it lasted 3 years because most that have only the tensioner replaced have problems 1 year or even a few thousand miles. My 07 Mini Cooper S started having issues with the timing chain/tensioner at 47k.
Check out the thread dedicated to the tensioner/timing chain debacle here.
Since the dealership has already replaced the tensioner once and at 92K I have little doubt the timing chain needs replaced.
It is unfortunate but once Mini Cooper once replaces the tensioner they write your Mini off as timing chain problem resolved and will not be willing to replace the timing chain at a latter date should the rattle reappear.
Too late for you but for anyone out there that starts getting the "rattle" my opinion is that you would be best advised to replace the tensioner yourself and then, if the rattle goes away, wait for the rattle to come back (it will) and then take it in to the dealership for a complete timing chain replacement ( which by that time it will need).
With 92K miles and 1 tensioner+chain change in the past (I assume under warranty, so more than 42K miles ago), you can start by replacing just the tensioner and see if it makes the rattle go away. If the chain is stretched, it wont.
The other thing I would do is run an oil analysis the next time you change oil. Blackstone Labs does it for just $25. Among other things, it will tell you whether the chain is slapping around and breaking down the plastic/silicone rail guides:
http://www.blackstone-labs.com/free-test-kits.php
Not much more useful stuff to be seen with valve cover off. Interesting, but not very useful.
BTW, how did you manage to crack the valve cover!?
If you intend to keep the car forever, I would consider replacing tranny/diff fluids as well.
a
09R56
11-16-2022 10:49 AM
