R56 NCS Expert + 56 => coded, but don't react to.
I all, i have a problem which is bizzare...
I successfully coded my car but, the new function aren't activated !
I know it's paradoxal, but after coded the car, i shut down for around 1 minute, and try the new function. It doesn't work.
I read the module again and the new function are clearly coded.
Does i need to do something ?
I try to disconnect the battery to restart the system but it doesn't work anymore.
This is the detail of my procedure :
Before, i check the fold "WORK" and delete file FSW_PSW.TRC ou e FSW_PSW.MAN
Then, i create a FSW_PSW.MAN with notepad.
- i charge a expert profile
-i do F1 next F3 then R56
-F6 to go back
-F4 process CPU then FRM
-I read the CPU F4 => new windows open
- i get back to the "WORK" folder and open FSW_PSW.TRC, i made some change and save it to FSW_PSW.MAN
-i go back to NCS, F6 to go back
- I click on process CPU
- I check if the coding mode is SG_CODIEREN
-F3 execute the job
=> some second after he told me "coding ended"
If someone have any idea....
I use the V45 datens.
-F6 to go back
-F3 execute the job
Hello,
I try to use for coding but it doesn't work...
I try to desactivate the auto roll down of the passenger, and it was a success.. i reactivate it after and he work again.
There is only a problem with the auto roll up passenger... Does it possible that my car could not have this function ? It's one of the firt R56
thebordella
08-31-2015 01:37 PM
1chaos52
08-24-2015 01:28 PM
JHolland
08-13-2015 10:47 PM
skippermini
08-13-2015 06:13 AM
