R56 Spark Plug Socket Stuck!
Gentlemen, I'll try to keep this brief:
Basically have a stuck Spark Plug Socket in the Spark Plug Tube of the Head. Intention was to do a typical change of the plugs so I used all the 'typical' tools. I was mistaken. I know now it needed to be the 12 point 14mm 'thin-walled' socket which is now in my possession but doesn't help the current situation.
The question is how can I get this socket out without taking the whole Head off?
Here's what I have already tried:
- Torching the walls of the Head and the Socket
- Winching a close hanger in the top of the socket to pull
- Locking Socket Extension Arms (all 3 of which broke)
- WD40 to losen the walls (the socket now spins)
- pry it loose with a screwdriver
(I haven't tried the upside down can of 'dust-off' to contract the metal)
As of now, the Valve Cover is off and my brain is fried. All the forums I have tried to search were no help. Any wisdom out there that can be shed on this? It's my daily driver and have been out it now for about 2 weeks now!
Cheers to you all
Cheers to you all
I think he means that the socket is not letting go of the spark plug, have you tried turning your car upside down? That was a joke, what you need is one of those long spring that has claws that shoot out to grab things just like this. I feel you pain because recently I performed a compression test and the adapter unscrewed from the hose for the gauge, had to fish it out using a Steelman (10150A) 16" Pro Bend-A-Light. It's one tough tool and the light at its tip can take some serious abuse, be careful cause when it's lit for more than 30 seconds it will burn your skin in a heartbeat!
I jammed this into the adapter to get it out, it's bendable in any shape (like my wife). I dare you to try and harm this tool, you won't be able to.
Thanks for all those quick responses.
The socket is caught on the Head (about an inch away from the spark plug).
Tried the 'Dust-Off icing' this morning and it didn't budge.
Kaneguy: Hadn't thought of a long bottom tap. That may just work. Will need to pick one up.
Any other critiques out there? I can't be the only one that's experienced this (or maybe i am (!))
Cheers
Cheers
Cheers
Cheers
I would be looking for a strong hook - to reach into the socket's hole and grab from inside/underneath the lip then pull up. It needs to be STRONG so you don't bend the hook b4 you pop the socket free.. It needs a strong handle - a T handle would be ideal. If you could get TWO and have them pull opposite sides to ensure a STRAIGHT pull ... better
Something like the second down here
I've seen exactly what I'm envisioning sold as a body work 'dent puller' .. you would drill a hole in the dent and slip the tool's tip in, then you could pull the dent up (not to be confused with the 'slide' type dent puller tho .. same concept but kinder and gentler!)
Worst case I'd make what I needed like this ... but maybe you don't have a welder in your garage ....
OR how about making an inside grab gear puller out of a long molly bolt - the kind with spring ears that you can sick down into the socket - a bolt and a big washer would allow you to use the screw torque to exert a lot of up pull . . . but if you socket is 1/4 inch drive you have a small hole to work with
But in the end I'd try to grab the socket from inside, even going all the way down to the base - I'm envisioning the socket got stuck b4 actually grabbing the plug.
I would not waste my time with super glue as IME it won't stick to a polished socket surface ... but red lock tight? Maybe?
Remember - every time you try to stick something into or onto that socket from the top is pushing it farther DOWN . . .
I did this to a Toyota a few years back, but was able to use a hook and get it out without TOO much effort.
Appreciate all the Feedback.
Conclusion: Submitted my pride and took it to a shop. They equally had a difficult time pulling it out. Ultimately, they welded a good sized bolt upside to the socket, then screwed in a bar to the bolt to pull it loose. They never felt something so stuck either.
Head is a little scared on the inside of the Spark Plug Tube but nothing that will affect drivability.
Cheers to you all.
Cheers to you all.
I think I get it:
They flipped a bolt upside down and welded it to the visible part of the socket. Then they threaded a nut down on the bolt with a piece of bar steel with a hole cut out for the bolt pressing down on the top of the engine. This slowly with every turn of the nut, pulled the socket up and out.
Good welding job, that was tricky.
Cheers to you all.
Cheers to you all.
Just for kicks, here's a few photos to show the misery in action
[IMG]<a href="http://s36.photobucket.com/user/kingstonco11/media/IMG_0510JPG_zpsf08e609d.jpeg.html" target="_blank"><img src="http://i36.photobucket.com/albums/e41/kingstonco11/IMG_0510JPG_zpsf08e609d.jpeg" border="0" alt=" photo IMG_0510JPG_zpsf08e609d.jpeg"/></a>[/IMG]
[IMG]<a href="http://s36.photobucket.com/user/kingstonco11/media/IMG_0511JPG_zpsc8f570fc.jpeg.html" target="_blank"><img src="http://i36.photobucket.com/albums/e41/kingstonco11/IMG_0511JPG_zpsc8f570fc.jpeg" border="0" alt=" photo IMG_0511JPG_zpsc8f570fc.jpeg"/></a>[/IMG]
OK. Now I have the picture. But, the spark plug is still in there? Why not just remove it by turning counter clockwise? Also, what does the socket lock under?
But at least I see how they did the welding.
///Rich
///Rich
eliseo1981
05-10-2016 06:19 AM
kjd186
09-09-2015 11:02 AM
09-02-2015 10:05 AM
