R56 Too much torque for Auto Trans with Billet R56 Turbo
#26
No it didn't. Perfectly fine. Autocrossed the car without a hitch.
Did more driving and I have to say a better way to describe the symptom is: the tranny is disengaging, going to neutral, then grabbing the next gear with a chirp from the tires.
After more research on "transmission malfunction", I think I'm going to have the transmission ECU reset. Read that some peeps do this on a regular basis with Aisin six speed trans. Wonder if ECU flash and Jb+ with new turbo threw the tranny's adaptation for a loop. Dunno, perhaps I'm in denial of the tranny death rattle....
Got a date at Buttonwillow Raceway next weekend. Will have dealer (yikes) reset tranny, run track and see what happens... Fingers and toes crossed.
#27
#28
UPDATE 2: Got tranny adaptation values reset by an independent shop. Unfortunately, the tranny continued to slip. Brought the car to JE Motorsports in Mission Viejo CA. Jawed Ekhlas (owner) insisted I flush the tranny fluid before attempting a valve body replacement. Jawed came highly recommended by a prominent tuner, so I listened.
Upon dropping the pan, we found some debris and the tranny fluid was black-ish brown. We cleaned all the debris and dirty residue from the trans... replaced the filter and gasket... TA DA!!! No more slipping!
Well no more as of now... will report back after this weekend at Buttonwillow Raceway. This will be the ultimate test. We'll see if the trans holds up.
#29
#30
#31
UPDATE 3: It was a very hot weekend and we drove the car hard. The tranny made it through both track days without a hitch. So glad we decided to just change fluids... it really helped the auto transmission. Definitely recommend 30k intervals.
I will swap out the fluid for synthetic as previously suggested. Just wasn't sure if this was going to work so we used what we had...
Hope this thread helps another automatic owner!
07-16-2020 12:54 PM
12-05-2016 06:31 PM
devicemanager
06-17-2016 06:18 PM
Norton70
R57 :: Cabrio Talk (2009+)
08-18-2015 04:29 PM
Ambient Thermal Management
08-07-2015 12:27 PM
