R56 hood scoop warping!
#26
Hi all,
I'm sure there's probably a thread on this somewhere already, but I searched for a while and found nothing. So here goes. I have a 2007 MCS with a plastic hood scoop. The heat from the turbo has warped it slightly in the middle....:frown: I removed the black honeycomb grill-like thing, seeing as though it renders the scoop basically useless....I was wondering if there is a solution to the warping and if I should be weary of debris entering my engine bay through the scoop. Should I put the honeycomb grill back on? Thanks in advance for anyone with some useful info.
#27
#28
After reading a lot of negative things about heat shields and turbo blankets, I've decided not to invest in them. However, if I purchase a different hood scoop made of a different material, would that fix my issue? If so what material scoop should I get and where can I get one?
http://www.waymotorworks.com/mini-co...5-r56-r57.html
#29
#30
MINI did in fact change the material of the scoop. When I had mine replaced under warranty in 2012, they also provided the aluminized MINI shield.
While I was waiting for the replacement scoop to be painted, and have 3m clear bra put on, (which MINI originally did not want to pay for, but after much bitching, they did install the clear bra for free), I bought the JCW carbon scoop, and installed the heat shield. No issues since...
#31
Cobra Cloth
Always had the carbon fiber hood scoop, so no problems with warping. I did recently line the majority of the underside of my hood with Heatshield Products Cobra Cloth. It's a woven fabric made out of aluminized fiberglass - looks like white carbon fiber. It's good for 1100F continuous, 2000F intermitant heat. My hood barely gets warm now.
#32
Seems like the CF factory ones hold up vs the old stock plastic ones need the heat protection.
Carbon Fiber JCW Bonnet / Hood Scoop 51130415378
http://www.ecstuning.com/Search/SiteSearch/51130415378/
The newest part number for the stock ones, recommend getting the new shield also.
Primed Bonnet / Hood Scoop 51132757694
http://www.ecstuning.com/Search/SiteSearch/51132757694/
New shield and insulation: post #42
https://www.northamericanmotoring.co...ut-this-2.html
#33
My 2012S doesn't have the carbon fiber scoop -- and that's why I'm searching through these threads today. The dealer installed a heat shield for me (metal strip on hood) but I had to pay for it. It was small enough to be worth it. I had already replaced the grill in the scoop with something less restrictive (chicken wire, I think).
So now that I've got the heat shield, I am here to ask: what's the best brand of stripes to use for my 3rd replacement set of stripes? The first set turned brown. That's when I bought the car. I replaced the scoop grill with the chicken-wire like substance and replaced the hood stripes. Now they've bubbled so much they need replaced again; that's why I got the heat shield.
Unfortunately, my stripes go straight down the middle. I love the look! But they go over the hot part of the hood. Maybe now that I've got the heat shield, the third stripe replacement will actually work and stay in place.
Know of a good source for heat resistant stripes? I need carbon fiber (look), 8.5" wide middle stripe, with two 3/4" stripes surrounding it. Unless I want to redo the WHOLE car, which I don't.
(Should I have started a new thread? Hot hoods was very much in my mind while searching ..... ) (Errr, hot bonnets!)
Deb
Deb
#34
Where have they turned brown, you can get a larger piece of insulation , like the stingray shape one above, a Diesel version also or a full cover from the R58 for car with the dual sport stripes ?
#35
888.280.7799 | 6am - 5pm PST
#36
Might try contacting www.MightStripes.com and see what they have to say. We got our stripes from them for our MINI. I'm not sure as far as heat resistant, but might be able to give them a call or shoot them an email and see what input they may be able to provide as far as plausible stripe options that you can go with.
Deb
#37
No worries, Deb! Hope you get something that works out for you. Good luck.
#38
Before you start replacing stuff I'd suggest getting as many heat shielding products as you can and using them all. My R56 had the scoop replaced at least twice in 49k miles and it's warped again and the stripes are cracked. Might be because it's chrome, which I hate, but I'm going to get an aerogel wrap for the turbo, M7's plate with more aerogel, and at least the diesel own hood piece before I replace it again.
#39
Colt45Magnus
10-01-2015 04:08 PM
