R56 r56 valves or rings?
So I'm trying to diagnose a bad ring or burned valve. I have done a compression test on all four cylinders and the fourth one just hissed when cranking. There is no colored smoke coming out the exhaust. The plug is wet from gas. Also, when the engineis running it seems gas is getting into the oil. Im thinking about dropping the pan and checking for debris. I also thought about doing a leak down, but need to find a gauge first.
One question....
Sounds like you are on the right path....
But the gen2 cars often get so much carbon on the valves, they loose compression...
Have you looked or tried to clean them yet? Have seen MANY gen2 cars get towed into my local shop, even 2 in one day, with dead cylinders, zero compression, due to carbon on one cylinder ... Such a common event on the "prince" motors...gotta bring it up...
Now tuned cars DO have piston failures...the stage 3 tunes are too strong for stock internals...the pistions fail in the "skirt" area around the wristpin and the rings...basicly takes out the motor, gouging the block...
Oddly enough I had someone do the blast at a mini dealership and the car is stock. I'm heading up to northern tools this afternoon to pick up a leak down gauge. If I have time this afternoon I'll report back. But, it might be til tomorrow. So from what I gather the piston that's being tested has to be at tdc correct? What would be the easiest way to position it?
Thank you all for the valuable info. BTW, anyone from Houston?
07-16-2020 12:54 PM
Lex2008
08-16-2015 08:33 PM
