R56 08 Cooper S R56 cranks but won't start
2008 Cooper S R56 engine N14
When push start button engine cranks but won't start.
No fault codes
Battery replaced 9 months ago and charge is ok
Spark plugs checked ok
Fuel high pressure pump replaced
In tank fuel pump fuse ok
You can hear pump starts when door is open
Any ideas please and how we do a fuel delivery check
No fault codes
If the engine is cranking you can try pulling the plugs and if they are wet you are least getting fuel into the cylinders. Some cars won't spray the injectors if they don't see some sensors plugged in. IDK if the mini is like that or not. You're not getting any CELs? Have you recently done any work on the car?
09R56
11-16-2022 10:49 AM
07-16-2020 12:54 PM
Accessory Products
08-11-2015 12:19 PM
tippin
08-05-2015 08:43 AM
