R56 Blue Smoke - Possible Blown Turbo?
Old 02-17-2015, 12:39 PM
mrice0118's Avatar
mrice0118
mrice0118 is offline
Originally Posted by SPRINTCARS
You don't have to pull the head to replace the valve seals.
I assume I would need to pull the cams though. I have never done any OHC work.
  #52
Old 02-17-2015, 06:29 PM
pokeyjoe's Avatar
pokeyjoe
pokeyjoe is offline
Originally Posted by mrice0118
Update:
- Replaced Turbo
- Replaced DP
- Replaced both Oil Lines
- Did carbon cleaning
And I still have blue smoke...but not as much? The turbo did have shaft play compared to the JMTC JCW turbo. Maybe it's normal, not sure. At least I know it's the valve seals now.
If the turbo was blowing oil out the exhaust, the cat is soaked and it will take a couple days to burn off. You may be done.
  #53
Old 02-17-2015, 06:47 PM
CPap's Avatar
CPap
CPap is offline
Also, some of the oil will be burnt onto the cat clogging it up... Causing back pressure and prematurely wearing down the new turbo thrust bearing.
  #54
Old 02-18-2015, 05:53 AM
Grizld700's Avatar
Grizld700
Grizld700 is offline
Looks like in the list the OP says the DP was replaced as well, so that would have taken care of any cat issue.
  #55
Old 02-19-2015, 07:49 AM
mrice0118's Avatar
mrice0118
Yea, my turbo did not fail...or at least not catastrophically. So it did not drop a ton of oil in the cat. Plus as stated above, I replaced the DP/Cat.
Should I worry about the second cat causing Back Pressure? Below is a picture of the inside of the 1st Cat. I guess it looks ok?
  #56
Old 02-19-2015, 08:10 AM
BlueThunder's Avatar
BlueThunder
BlueThunder is offline
Check back pressure
The photo of your cats. Look pretty bad. I've done a few r56 where cat was so clogged the car wouldn't even start. If you can do a back pressure test on the exhaust.
  #57
Old 02-19-2015, 10:26 AM
CPap's Avatar
CPap
CPap is offline
Yea, my turbo did not fail...or at least not catastrophically. So it did not drop a ton of oil in the cat. Plus as stated above, I replaced the DP/Cat. Should I worry about the second cat causing Back Pressure? Below is a picture of the inside of the 1st Cat. I guess it looks ok?
Yes, a clogged second cat will cause back pressure. If your valves are leaking and you're still spitting out oil, I'd worry about the new dp(if it's got a cat) and ultimately the turbo.
  #58
Old 02-19-2015, 11:54 AM
rckrzy1's Avatar
rckrzy1
rckrzy1 is offline
No mods with 93k.
I can do the compression test. I have an old one to get me started. If they check out OK, should I still have a leakdown test?
Jeez, what did I get myself into? I did some research on MC before I got this. I knew they were not the most reliable, but I figured I could take care of most things myself. Not sure I am ready for a overhaul. Uggg
Thanks for the replies!
you bought a N14 , I guess one of the what MINI said is normal using a quart of oil every 1K BS .
  #59
Old 03-16-2015, 07:20 AM
mrice0118's Avatar
mrice0118
I have been doing research on valve seal replacements on this engine. Doesn't seem like much information about it. I don't even see anything about it in the Bentley manual.
I have seen a lot regarding the BMW N62 engine. Are the valve trains similar? If so, it looks like it wouldn't be hard to do with head on. Check out this video on the N62:
Colt45Magnus
08-27-2024 05:03 AM
embiggenedmini
10-15-2015 12:36 PM
eliseo1981
09-04-2015 02:33 PM
09-03-2015 01:45 PM
Sean Pine
Massachusetts Motoring Club
09-02-2015 08:16 PM
Quick Reply: R56 Blue Smoke - Possible Blown Turbo?
