R56 Timing Chain Tension
I had to remove the timing chain assembly from my engine recently. The problem im running into when installing is how tight the chain has to be between the vanos and ex sprocket. The first time i did this was perfect (i thought) no slack. Everything snug, but when I tried to replace the top guide rail, it was literally sitting on top of the chain and i could not screw the two bolts on to the head unless i pressed down with pressure against the chain. What am i missing here?
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
iamcamkeenan
08-10-2015 03:31 PM
