R56 cam timing question
Old 03-15-2015, 08:24 PM
shanksamillion's Avatar
shanksamillion
shanksamillion is offline
Originally Posted by SPRINTCARS
is the tensioner still installed ? I just assembled mine to check piston to valve clearance and did not have that.
Something's wrong. That should not have that much slack. Just start from scratch
I haven't taken anything apart on cylinder head or to access chain. It was like that when I removed valve cover and chain guide to inspect. Probably bad tensioner right? Car won't start. Trying to figure out why.
  #27
Old 03-15-2015, 08:46 PM
ti_tony's Avatar
ti_tony
ti_tony is offline
Tensioner takes up slack between the cam gear and the crank gear, with slack between the cam gears check the vanos.
  #28
Old 03-15-2015, 09:18 PM
SPRINTCARS's Avatar
SPRINTCARS
SPRINTCARS is offline
How's the flats on the opposite end of the chain?
Are they straight up and down with the crank pin in ?
The tensioner should be pushing on the chain.
In theory pulling counter clockwise on the intake cam taking the slack out. Or pulling on the exhaust cam clockwise.
When I did mine,
Installed crank pin
Crank bolt, bolt cam bolts were loose
Turned the cam to correct position and installed the cam alignment tools.
Installed the tensioner
Tightened crank bolt and cam bolts.
That slack you have I didn't have.
You need to get those tools. Trying it any other way is gonna cost you time and some major headaches. Once you get them your gonna think I should have gotten then first off.
Either that motor jumped teeth or the VANOS is messed up. Either way you need the cam tools.
  #29
Old 03-15-2015, 09:19 PM
SPRINTCARS's Avatar
SPRINTCARS
How's the flats on the opposite end of the chain? Are they straight up and down with the crank pin in ? The tensioner should be pushing on the chain. In theory pulling counter clockwise on the intake cam taking the slack out. Or pulling on the exhaust cam clockwise. When I did mine, Installed crank pin Crank bolt, bolt cam bolts were loose Turned the cam to correct position and installed the cam alignment tools. Installed the tensioner Tightened crank bolt and cam bolts. That slack you have I didn't have. You need to get those tools. Trying it any other way is gonna cost you time and some major headaches. Once you get them your gonna think I should have gotten then first off. Either that motor jumped teeth or the VANOS is messed up. Either way you need the cam tools.
PM'd
  #30
Old 03-15-2015, 09:49 PM
Sheppard06's Avatar
Sheppard06
Sheppard06 is offline
Did you solve this mystery? I am in a similar situation... just seeing what you came up with.
  #31
Old 03-15-2015, 09:56 PM
shanksamillion
Not solved. I haven't done anything to my timing chain. It was already like that. I think tensioner went bad again. Waiting for other responses.
  #32
Old 03-17-2015, 06:28 AM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Originally Posted by shanksamillion
2) Compression test post carbon clean revealed very low almost no compression in all cylinders. Didn't test before clean, no tester at that time. Dry test 1=15, 2<15, 3<15, 4=28. Numbers doubled wet but still waaaay too low.
Not good. Nor the sounding like a buckets of bolts rattling around. A boroscope comes in handy for peeking in the cylinders and looking at valves. Also when your looking for that bolt you dropped that magically vanished into thin air. Some models have a smaller head that fits thru the spark plug hole with room to spare. Look for one that includes a 90° adapter to let you examine valve movement while someone turns the engine by hand with a ratchet. Hopefully there's no holes in the pistons or bent valves.
This one might be an option.
http://m.harborfreight.com/high-reso...der-60695.html
  #33
Old 03-17-2015, 07:09 AM
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by Tigger2011
Not good. Nor the sounding like a buckets of bolts rattling around. A boroscope comes in handy for peeking in the cylinders and looking at valves. Also when your looking for that bolt you dropped that magically vanished into thin air. Some models have a smaller head that fits thru the spark plug hole with room to spare. Look for one that includes a 90° adapter to let you examine valve movement while someone turns the engine by hand with a ratchet. Hopefully there's no holes in the pistons or bent valves. This one might be an option. http://m.harborfreight.com/high-reso...der-60695.html
+1 for tigger
09R56
11-16-2022 10:49 AM
Teh
08-22-2022 04:37 AM
Svejk
02-24-2019 12:18 PM
emulajavi
12-24-2018 09:15 AM
nomar116
08-10-2015 11:24 PM
Quick Reply: R56 cam timing question
