R56 Backup Camera Shuts Off After 10 Seconds
I installed an aftermarket backup camera in my 2009 Mini. It works great for about ten seconds then turns off.
The camera is wired to the backup light circuit. The display is wired to an ignition source. I also tried the display to a separate power supply. Same outcome.
My guess is that something happens to the backup voltage after about ten seconds. Does anyone know what could be going on? The camera and display work perfect on the bench.
Yes, I do have Bluetooth.
I just measured the reverse power circuit using an oscilloscope. The voltage goes to a constant 12 volts when the vehicle is shifted into reverse. After 10 seconds the voltage alternates between 12 volts and ground. It stays at 12 volts for about 12 milliseconds and then goes to 0 volts for 5 milliseconds and then repeats.
My guess is that this extends the bulb life.
Here is my solution.
I installed a small 2 amp diode in series to a 200 microfarad capacitor shunted with 2000 ohms. This reduced the chopped waveform to a high degree. There is a bit of flicker but very tolerable. I mounted the 4.3 inch LCD in the little cubby below the AC controls. What a difference being able to see behind the mini convertible.
They are the standard filament type bulbs. My guess was the chopped voltage waveform was to extend the life of the bulbs using an AC voltage but it may also be linked to determining if the bulb is operational. In any case, my rectifier circuit is working great. I would like to find a better place for the display.
back up shut off
I saw another forum where the described the cameras in a Mini. The rear camera turns on with the power of the backup lights and shuts off when you move out of reverse. The forward camera input turn on for 10 seconds only, then the system moves back into Nav. Are you in the correct input?
Consider adapting the mount used for the MINI Garmin accessory (official name MINI PORTABLE NAVIGATION XL SYSTEM)?
https://www.northamericanmotoring.co...-opinions.html
If interested, Google these part numbers for a start:
Bracket 65902348476
Installation Kit 65902351407
MINI Portable Navigation XL 65902348018
Because the steering wheel significantly obstructs the view of the optional Garmin XL in any position EXCEPT top dead center, going to the right is not really a viable option for any display that you actually want to . . . umm . . . see.
This Garmin mount has various detents (holes drilled in the pivoting frame) and stops at various positions by means of a small ball bearing that engages those detents and stays put via friction.
Mine would not go past about 10 o'clock - essentially worthless - so I removed it for a quick 'look see' - as I am wont to do.
Sure enough, full pivot movement to the top had been purposely defeated by means of rivets put into the relevant detents - I'm guessing as a post-design modification at the advice of counsel for liability concerns. So I ground out the rivets, drilled a few more strategically placed detent holes in the frame, and can now swing the Nav all the way up when I need it, but keep it down at 9 o'clock and out of the way when I don't.
The openmeter is a guage that goes up to 6 hours. It has some segment lights that indicate hours and a needle pointer that shows zero to one hour. A bit foolish but it does make me feel good when I see that I have been driving around for many hours with the top down. This all requires a lot of SPF 50, but in south Florida that is SOP.
RobbyD
01-29-2019 01:22 PM
Nicefeet
09-24-2015 06:53 PM
jumbojimbo
09-24-2015 08:16 AM
