R56 O2 sensor replaced, still asking for it
My '08 base model (72,000 miles) gave me at the check engine light a couple of months ago, so I pulled the code to see what repairs it might need and it ask me for a new thermostat housing, so I replaced it.
A couple of hours later the dreaded check engine light came back, but this time it gave me a p0136 fault code which pertains to an O2 sensor circuit (bank1 sensor 2). So I replaced the second, after the CAT, with a NTK sensor. Cleared the code, drove it for about 3-5 mile and the check engine light came back!!
So I checked the codes again and it gave me p0136 again!
Was i supposed to change both sensors?
Does my CAT needs to be replaced?
Any ideas or suggestions will be greatly appreciated.
Stock exhaust? Might want to check the condition of the cat.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
It is for the post cat sensor. I'm pretty sure that DME is covered under a special emission warranty for O2 sensor issues. Make sure the valve cover gasket isn't leaking into the wiring harness or the O2 sensor. If the V/C is not leaking now, but was in the past, check to make sure there is no oil residue. If all is well there, check with your dealer about the warranty as it's, I believe, 10 year or 100,000 mile warranty on this particular issue.
-Luccia
-Luccia
-Luccia
-Luccia
Unfortunately not. A Mini specialist here advised me about it and said the best way to find out if someone qualifies is to call their local dealer.
-Luccia
-Luccia
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
silence2-38554
98
09-21-2016 02:52 PM
squawSkiBum
10-02-2015 09:21 AM
JPMontes3
08-23-2015 01:26 AM
PSIChocolate
08-13-2015 12:46 PM
