R56 Blown turbo??
#28
That link redparchel shared completely points at the turbo in one way or another. The pcv valve isn't it for sure now because I just put the brand new valve cover on a few days ago, the old one however was clogged, but the issue of smoke actually got worse after that. It never smokes at idle. Always in heavy throttle. Then once I'm past the low rpms all of a sudden it hops off limp mode and gets its power back and pulls away and no smoke.
#29
Like I said I had the same issue and replaced the diverter valve. Do not take the valve out unless you have a replacement ready because if it is broke it will really fall apart as you remove it. Also be aware and take caution when removing the valve as broken pieces can fall into the turbo. You can get the diverter valve from ECS for a decent price if you check with them. You can also go to Pelican Parts and find it fairly priced as well. Good luck and keep us informed.
Erik
Erik
#30
I'm about to get the compression test and check the hoses and lines out here in a couple hours at our shop. I would be stoked if all this is just being caused by the diverter valve. Makes me wonder, since I haven't heard any real blow off noise in weeks, leads one to think that could indeed be the cause. Just didn't think it'd cause limp mode and all that smoke.
#33
#34
#35
Stock turbo is here for the MCS just for comparison. $800.00
http://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Turbocharger/
#38
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 07:08 AM
EVMini
09-28-2015 11:20 AM
