R56 The answer to all my problems?
Could bad spark plugs be the issue with my car and give is a P0014 engine code?
I have crappy throttle response after a bit of driving horrible fuel economy and no power on the top end.
I really hope this could be the issue because i've tried changing the camshaft sensor and the vanos solenoid and i cant really afford to keep on changing sensors until it fixes the problem...
Is your car an S or a base cooper? If it is an S, you have enough miles to need new plugs (60k for S is what I remember). Your plugs have a decent amount of buildup on them.
Depending on the year of the car, there may be carbon buildup that can also affect stumbles and hesitation.
Have fun,
Mike
Have fun,
Mike
I can't say it will make your P0014 code go away, but I would go ahead and change those plugs if they have 53k miles on them. They are supposed to last longer (75k?), but many here have had problems at 40-55k due to spent plugs and/or ignition coils. Replacing the plugs is an easy DIY job, and even if they are not causing your P0014, you're going to need to replace them soon enough anyway. You can't just go by looks—mine didn't look bad either, but they certainly were.
I replaced my plugs ('10 Justa Mayfair) at 54,000 due to performance problems (bogging and missing at lower throttle levels) and various cylinder misfire codes. That got rid of the codes and restored performance almost completely, but there was still an occasional miss or hesitation. Replacing the ignition coils cured that and all has been well for the last 5k miles.
I did my plugs one week, then changed the coils the next week since I was trying not to spend money if I didn't need to. But it's best to change them all at once because bad plugs can reduce the life of the coils and vice-versa. I spent $18/plug and $32/coil.
I believe it's time to take your Mini to an expert, there's not much else I can think of that might fix your problems. Tell them what a going on about your bad gas mileage and everything else you have mentioned.
Or you could continue to replace parts until it's fixed which I don't think is a good idea.
on
VANOS is a secret BMW word for your car is F up. I don't even know why I read the codes in my car. I use the code reader and still have no idea what is wrong. Take it to the dealer sit in the wait room with the big glass wall over looking the shop and watch the tech look at the big screen above their work station and then watch fiddle with car and look at the big screen again. Don't know if it Fox NEW OR ESPN they are watching. LOL
Again just because it states the "vanos adaptation stop" code doesn't tell you what's wrong with your car other than a cam problem, there's more than one thing that can cause that code. Why do you resist getting you car looked at by an expert? You need more help than we can give you, sooner or later you'll realize that. Good luck.
Check the condition of the plugs and wires that go into the end of the valve cover - the wires are inside that shroud you remove to replace the thermostat on the Justa.
Sounds like an intermittent problem, pricey at the mechanics to troubleshoot but how else are you going to test the coils? Their machine can show the amount of juice going through them, although those old plugs did look ok to me.
I didn't say he needed to take it to the dealer, I stated there's not much else we can do to diagnose the OP car. OP has been throwing new parts at his Mini in hopes it would resolve the issues, it has only removed $$$ from his wallet that could have been used to have his Mini looked at by a mechanic. Whenever you're having Vanos issues you've got serious problems, finding a mechanic that knows about Vanos outside of BMW is difficult.
I do know what the problem is, Vanos. Problem is troubleshooting the Vanos is no easy task.
