limp mode (Safe Mode) how to fix it
Hello
i have mini r56 and im in limp mode (Safe Mode) how to exit from it or reset it
i have this code sortted only
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
please help me to fix this and what should i do
thanks
thanks
A new O2 sensor will fix this, clearing the code should be done after fixing this, clearing the code will not fix the faulty O2 sensor. ECU will not necessarily go into Limp Mode every time a code is thrown.
If you had Googled "P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)" you would have found your problem here which tells you what's wrong with your car.
hi thanks for your replay
what should i replace which is located on top or bottom
thanks
i mean after cat or before cat ?
i have replaced o2 sensor and check engine go away
and im still in limp Mode (Safe Mode)
please help what should i do the car runing very slow
everything is new spark plug and coils and all filters Fuel Air And Oil Filters
mini-is-for-me (11-02-2019)
Disconnect the battery for an hour then reconnect, that should reset the ECU. Which O2 sensor did you replace, Bank 1 Sensor 1 or Bank 1 Sensor 2?
https://www.google.com/search?q=Bank...thtsjoku9iM%3A
and i have disconnect battery and still the same
BlueMiniac (03-11-2020)
i never did figure it out, couldn’t afford to keep throwing parts at the car, ended up selling it but still stuck on it afterwards thinking what it could’ve been I landed on most likely my issue being the diverter valve. Hope that helps!
thadscottmoore
06-04-2021 07:19 AM
Sc00terbum
09-11-2015 07:17 AM
