R56 should I buy a 2011 MCS S used
HI I am considering a 2011 mini Clubman S used. I had a 2008 mini cooper S that i sold in 2012 due to carbon issue , thermostat and then Chain rattle that came back even after the fix.
Now it will really help if I can get some answers on this 2011 year engine . Thanks in Advance.
1) May I know when mini changed the engine to N18. The vehicle I am looking is delivered to the previous owner on April2011. is there a way to check looking at the engine.
2) How are N18 engines compared to N16. are there any items that i should check specifically while looking at the car.
3) Looking at Car fax this one already had fuel pump replaced at 15000, mils. It now has 39000 mils.
If the owners can chime their experience good or bad. That will help me a lot.
Thank You.
Pavan
Thank You.
Pavan
There's just too many issue with the N14 engine, Mini changed the engine to the N18 in mid 12011, April 2011 = N14.
It's inevitable for the timing chains to go bad do to seven years of badly designed timing chain tensioners, Mini just continued striking out! Some member's have gone through at least 1-2 timing chains especially when buying a used N14 equipped Mini, they consume absurd amounts of oil that ends up coating the intake valves with tons of carbon deposits.
Get used to adding 1-2 quarts of oil every 1000 miles and having your valves walnut blasted every 25-40K miles and your pistons covered in black baked on carbon that acts like a heat barrier cooking the pistons with high cylinder temperatures. Some member's have gone through more than two timing chains and that's usually when they sell them and get rid of them, too many problems!
It's just way too much risk buying any N14 equipped Mini, it's just a lousy financial bet your sure to lose. The worst use car you could possible buy!
Glad it's the N18. If you can, I'd get a reputable MINI indy shop to do a PPI on it before you purchase just so you know what may or may not need to be fixed. This way you at least have a good idea about the condition of the vehicle.
888.280.7799 | 6am - 5pm PST
