R56 adjustable control arms
Get Hotchkis adjustable control arms.
Hotchkis (H-Sport) has poly bushings with zerk fittings, so they can be greased
if necessary and will be effective and durable.
TSW has hard rubber bushings and would be another great choice, but not sure
if they're available right now.
A spherical or heim joint arm has even less flexthan the two above, but would
avoid an open designon a street car, especially if you have winter where you live.
The current Helix arms have a rubber boot over the joints if you want to go this route.
The stock will work, but you will have more negative camber in the back than ideal.
This will result in more wear on the inside tread in the back, and a little more understeer.
With adjustable RCAs, you can optimize things better.
BTW, I'm not a big fan of lowering as the suspension travel is already limited in the MINI.
Most people do it for looks rather than performance.
Vendor
Yeah we've used all the brands and found the Hsport rear camber links to be by far the best as they are the most reliable and quiet.
http://www.waymotorworks.com/h-sport...ber-links.html
888.280.7799 | 6am - 5pm PST
R50/53 Adjusting Toe on rear tires?
IQRaceworks
11-06-2015 03:38 PM
minisenpai
10-20-2015 04:11 PM
