R56 Timing Chain Class action Lawsuit Settled?
Looks like BMW has agreed to pay Plaintiffs attorneys $1.8 Million. I'm trying to ascertain what thew owners get.
http://www.law360.com/classaction/ar...gn=classaction
More details:
BMW of North America LLC has agreed to settle a class action lawsuit over allegations that certain Mini Cooper models contain an engine defect.
The BMW class action lawsuit filed by Joshua Skeen and Laurie Freeman alleges that Mini Cooper S Hardtops, Clubmans and Convertibles between the model years 2007 to 2010 have a timing chain problem that costs vehicle owners thousands of dollars to repair.
According to the BMW class action lawsuit, the Mini Cooper’s timing chain tensioner is off-sync, which forces the engine to work harder at the expense of the engine’s pistons and valves. In some cases, the alleged engine defect reportedly caused the entire vehicle to lose power.
Skeen and Freeman say they each purchased a new Mini Cooper S in 2007 and were told that the timing chains were supposed to last about 10 years or 120,000 miles. However, the plaintiffs claim they had to make costly repairs much sooner than anticipated.
In 2013, Skeen claims to have paid more than $3,000 to replace the BMW car engine that had 74,000 miles on it. In a similar situation, Freeman says the timing chain tensioner on her Mini Cooper was replaced under warranty in 2009 but failed again in 2013 costing her $1,300.
The BMW engine class action lawsuit claims that the car manufacturer has been aware of the engine defect since 2008 when they acknowledged the problem by issuing a technical service bulletin. However, the plaintiffs say that although the company knew about the issue they did not offer to reimburse BMW car owners for the repair.
If approved, the BMW class action settlement will reimburse Class Members 100 percent of the cost of repairing or replacing the timing chain tensioner at an authorized MINI dealer. In addition, the BMW settlement would extend the four year or 50,000 mile warranty to seven years or 100,000 miles.
The proposed BMW engine defect class action settlement was reached after more than a year of negotiations, followed by a full-day mediation between both parties.
I also wonder if the extended warranty covers just the timing chain components. I can't imagine them extending the entire warranty.
Yes, the extended warranty only covers the specified parts, not the rest of the engine, and definitely not the entire car.
Probably way early in the process to know anything for sure.
Notice received in snail mail yesterday: Timing chain lawsuit
Hi, folks.
Yesterday I came home to a letter with a form asking if I wanted to join the lawsuit.
Has anyone else received one of these? I haven't had a chance to read it thoroughly enough but if you don't have service documents, there is an affadavit for a mechanic to sign attesting to the routine maintenance of the MINI.
I am the original owner of a 2009 Mini Cooper S.
I need to read up more on this. I got an email today about it.
I've got a 09' Clubman S, but I'm not the original owner and the car was just out of the factory warranty (by years not mileage) when I got it. It had 48k on it. I researched the history and a MINI dealer replaced the timing chain in my car at 34k miles.
It's now got over 70k. No idea if they upgraded the tensioner.
I had my tensioner and chain on my 2008 S replaced last fall and paid out of pocket. In the letter, it mentions that you have to provide proof that you had adhered to the required maintenance. I did all my own oil changes, however. There is a section to get a mechanic, either MINI or 3rd party to sign off on it. Do you think I can just sign off as I did the work myself? I have since sold the car since it was becoming too expensive to maintain, but would like reimbursed since this was a common problem.
And I'm unsure about some of the language. It mentions, even if you do nothing, you'll be given an extended warranty of 7 years/100k miles from the Coverage Vehicle's "in-service" date.
What do they mean by in-service? Is that the build date? If so, hell I'm at 7 years now, which would make the warranty useless to me.
I'm on my 3rd tensioner, and the last one was paid for by me. Plus my chain is stretched beyond the spec described in the TSB so it seems like just a matter of time before I have to change the whole thing.
An in service date on a vehicle is when the original car warranty started on the vehicle when it was first purchased as a new vehicle. The in service date should not be confused with when the vehicle was originally manufactured, instead think of the in service date as the date that the first consumer drove the vehicle off the dealerships parking lot.
So if your car was sat on the dealer lot a year before it was purchased your warranty starts then.
This is a good question. I own a 2010 model yr MCS hardtop that appears to be excluded. Inexplicably, I just received the letter. One of the options in responding is to tell the court why you don't like the settlement. I intend to complain about the exclusion of the 2010 MCS hardtop. It may do no good but it's probably going to be my only opportunity to make the case.
For those that own an MCS I can't stress enough how important it is that you install the 5th final designed tensioner, it's so much smoother than any gen design before it as I had a rare opportunity to test a 3rd gen, 4th gen and 5th gen tensioner and it's night and day difference! The older gen tensioners were all the same even before installing new, the piston was anything but smooth which as you may or may not know is the reason why the tensioner gets stuck partially open not fully tensioning the timing chain which causes it to stretch and by the time it starts hitting the upper guide it's to late.
It took Mini 8 years to get it right, way to long for any manufacture!
Got it at a Mini dealer when I went in to have my chain slack measured before my 2 year warranty was up. The newer one doesn't have a dimple in the center, most places don't even sell the older generations anymore, only the longer tensioners.
