R56 Eninge Oil pan damage - question
Hi all!
I managed to hit a bump the other day that dented my engine oil pan from below. Aside from a tiny crack at the edge, resulting from the incident, the oil pan is still sealed and tight.
It does however have its (inward, to the car's center) bottom dented up into it some.
I was able to seal the crack with JB weld.
Now I started it up and it sounds as if something is mechanically hitting something else. I looked at diagrams but can not get a clear picture so here my question:
Is there something that protrudes into the oil pan from above that might be grinding against the more shallow oil pan bottom now?
I will add pictures tomorrow.
Edit 1: Car is a R56 2008 Mini Cooper Hatchback. I reside in the USA.
Edit 2: I realize that the header has "engine" spelled wrong but I have no option to correct it.
If you decide to remove the oil pan we have a DIY that may be of assistance.
888.280.7799 | 6am - 5pm PST
Need pics, how hard did you dent it ?
Get a new oil pan and seal. Call your insurance and see it they will cover it. Might hit s bad it knocked the oil pickup / strainer.
I would also get a skid plate for a little extra protection.
https://www.ecstuning.com/Search/SiteSearch/ES2840603/
Lex2008
08-09-2024 12:54 PM
studio47
12-04-2015 08:46 PM
