R56 Electrical system failure?
Old 12-27-2015 | 05:26 PM
Russell Simmons's Avatar
Russell Simmons
We have a 2009 Mini Cooper and woke up today to a new problem. Upon trying to start the car, all dash lights come on and off intermittently and although the car does start, it starts more sluggishly than normal. A red car on a jack is displayed on the display above the steering wheel and all dash lights including gas gauge indicators go off and on, including the radio, navigation display, and indicator lights such as check engine, brake, etc. I'm afraid to drive it off of the driveway, although it does seem to run fairly normally. Any advice is appreciated!!
Old 12-27-2015 | 06:20 PM
AZdsrt's Avatar
AZdsrt
How old is the battery? A marginal battery in these cars cause all kinds of wonky electrical problems in these cars..
Old 12-27-2015 | 06:54 PM
Russell Simmons
Thanks for your reply!! The battery has never been replaced. What's the easiest way to test the battery?
Old 12-27-2015 | 07:21 PM
AZdsrt's Avatar
AZdsrt
2009 and it's the original battery? Don't bother getting it tested, replace it. In any case, it's WAY past due and mostly likely your problem..
Old 12-27-2015 | 07:43 PM
Russell Simmons
I've read that if I replace the battery that there is a sensor on the battery that communicates with the alternator that must be reset. Does that sound correct, and if so, how is that accomplished?
Old 12-27-2015 | 07:47 PM
AZdsrt's Avatar
AZdsrt
IBS, Intelligent Battery System. It's a module connected to the positive (I think) cable. If you don't have it, nothing to do (not all Mini's have it). If you do, the threads I've read indicate you need to have it reset at a Mini dealer. Lots of thread on this, do a search on either IBS or Intelligent Battery System. Also, lots of threads on replacing the battery..
Old 12-27-2015 | 07:54 PM
Russell Simmons
Thank you for your help!! I'll give it a try in the morning.
Old 12-27-2015 | 08:22 PM
AZdsrt's Avatar
AZdsrt
You're welcome. I've been down this road with my wife's 2012 MCS. Weird electrical problems, but Mini started OK. I ended up having the dealer replace the battery and reprogram the IBS. Was about $250 total, solved all my problems. The heat here in Phoenix kills a battery fast. Good luck..
Old 12-28-2015 | 11:15 PM
Slave to Felines's Avatar
Slave to Felines
The IBS sensor is on the ground cable. You can see it in the following picture from Pelican Parts:
http://www.pelicanparts.com/techarti..._med/pic07.jpg
If you don't have that thing on the ground cable (the one on the right, with the green arrow pointing to it in the pic) then you can just replace the battery and go.
Old 12-29-2015 | 09:59 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The IBS is on the negative terminal and is pictured as slave has shown. If your MINI does have it and you don't register it the charge program will be incorrect, shortening battery life. As far as registering it, if you have the right equipment you can do it yourself and don't have to go to a dealer/shop. Our DIY can help you with the process.
888.280.7799 | 6am - 5pm PST
Old 12-29-2015 | 12:10 PM
More info here:
https://www.northamericanmotoring.co...mpossible.html
Old 01-05-2016 | 05:06 PM
Russell Simmons
Can I use a battery charger/maintainer to keep the car's memory settings? Is a charger/maintainer the same thing as a "battery tender?" Thanks.
Old 01-05-2016 | 05:58 PM
AZdsrt's Avatar
AZdsrt
Not quite sure what you're asking for? As far as I know, memory settings (ie radio presets) are stored in your key fob..
Old 01-06-2016 | 07:51 AM
That's the memory for the presets. Charger/maintainer same as battery tender in most cases.
Old 01-06-2016 | 08:38 AM
PelicanParts.com
Vendor
Yes, battery chargers/maintainers are the same as a tender. We have them HERE if needed. They help keep your battery in good condition, especially if the car sits for extended periods of time. They're a good investment so that you don't keep blowing through batteries.
MiniCS
03-08-2016 11:47 PM
Wisconsincooper10
01-04-2016 03:51 AM
ericyuhk
12-09-2015 01:23 PM
Wisconsincooper10
11
11-30-2015 05:49 PM
