R56 Mini broke
Old 01-13-2016, 09:24 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
Location: Greenville, SC in the United States of Awsome
Mini broke
My 2008 R56 103,000 miles will not start, the ignition goes but engine wont start.
Old 01-13-2016, 09:57 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Did you check over the basics, i.e. check for spark and fuel? Any codes present in the system?
888.280.7799 | 6am - 5pm PST
Old 01-13-2016, 10:10 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
there is gas and i can hear ignition, what do you mean codes? Im not much of a mechanic.
Old 01-13-2016, 10:21 AM
PelicanParts.com
Vendor
Although you are getting it to crank, still check the battery so that you can rule it out of the equation. I have seen instances where a bad battery was in the mix of things even if the vehicle cranked. Be sure to check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Do you have a scan tool that you can plug into your OBDII port to see if any faults are present in the system?
https://www.northamericanmotoring.co...n-t-start.html
http://www.mini2.com/forum/second-ge...-starting.html
Old 01-13-2016, 10:40 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
No scan tool, thanks for the help
Old 01-13-2016, 11:51 AM
ECSTuning is online now
Received 2,092 Likes on 1,866 Posts
We have one here for MINI specifically.
We just landed this Schwaben by Foxwell tool and it reads allot of things, I used it for ABS testing and it pulls and tells which side is bad. Also found allot of old stored codes for a dead battery in my R58 which is like a history lesson of the car, showed the faults in the climate control for the low battery. Unlike my Actron unit , which took a couple time, this read codes right of the bat. Pretty cool device and read much more. What it all preforms is listed in the Product Details on the item.
Once you have a check engine light or sometimes it will find codes that dont have a Check engine light, you can find that P code PXXXX and then google search it or copy and paste into the MINI forums search box and presto , you have some answers.
Professional BMW/MINI Scan Tool
https://www.ecstuning.com/Search/SiteSearch/ES2975699/
Old 01-13-2016, 11:56 AM
PelicanParts.com
Vendor
You could swing by your local Autozone and see if they can pull a code for you if you do not wish to buy a scan tool, but obviously would need a running car. Maybe you can borrow one from a friend? Once you do some digging let me know what you find out.
Old 01-13-2016, 01:28 PM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
i have a freind coming over to help me figure out the problom, ill let you guys know.
Old 01-13-2016, 01:31 PM
Thanks for the update, try to scan it with an actron unit ?
Old 02-04-2016, 02:30 PM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
Sorry to revive this tread, but my timing chain/belt died, whats the damage? Mechanic says its totalled.
Old 02-04-2016, 02:33 PM
PelicanParts.com
Vendor
You going to buy a new motor or depending on the extent of the damage do a rebuild?
Old 02-04-2016, 02:34 PM
Oh no. ;( If the heads make contact with the valves, then the pistons and valve train , plus rebuild the head and timing. If more broke or bent in the engine then the cost of a remain would be cheaper or a salvage one.
Factory Remain went up in price since last year :
https://www.ecstuning.com/Search/SiteSearch/11002158705KT/
Old 02-04-2016, 07:07 PM
JimmyChooToo's Avatar
JimmyChooToo
JimmyChooToo is offline
$3,500 on EBay for a turbo engine without the turbo.
Old 02-05-2016, 08:13 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
I am going to head to the mini dealer becuase i belive there was a recall for it. I may have to buy a new mini
Old 02-05-2016, 08:19 AM
PelicanParts.com
Vendor
Sorry to hear. Let us know what happens.
Old 02-05-2016, 08:26 AM
I am going to head to the mini dealer becuase i belive there was a recall for it. I may have to buy a new mini 😢
There was a TSB were one of the cars with the updated tensioner bulletin. if yours was not done. I had mine done. You can call the dealer and they can run your vin. It was 2007-~2009 MCS that had the older tensioner style and if your chain was stretched they replaced it also. If you have the old tensioner or the the TSB had not been done, they might work with you.
https://www.northamericanmotoring.co...00-mini-s.html
Old 02-05-2016, 09:52 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
Dealer said they will fix it becuase my mini was under the November recall. Hopes up
Old 02-05-2016, 09:54 AM
PelicanParts.com
Vendor
whooo-hooo!! Happy to hear this.
Old 02-05-2016, 09:55 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
R.I.P n14 2008-2016 :'(, at least im getting a replacement.
Old 02-05-2016, 10:04 AM
That's great news, glad they came through. If you need anything else I am always here to help.
Old 02-05-2016, 10:10 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
thanks
Old 02-05-2016, 10:14 AM
Welcome. I am here for my fellow N14 owners.
Old 02-05-2016, 12:31 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
The November recall? Why would Mini replace the entire engine?
Old 02-07-2016, 07:26 AM
BadgeFTW's Avatar
BadgeFTW
BadgeFTW is offline
becuase the car is now dead becuase it was never replaced.
Old 02-07-2016, 08:47 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
Quick Reply: R56 Mini broke
