R56 Sway bar end links
Sway bar end links
Just replaced both rear sway bar end links on my 2010 MCS (70 k mi). Both were replaced previously, at around 35 - 40 k mi. I used OEM parts at that time.
It's a pretty easy DIY but, still, is there a more durable replacement part option out there? The car has a Hotchkis bar, if that matters.
Vendor
It's not normal to see these wear out like you are having happen. But we do offer our adjustable links that are stronger
http://www.waymotorworks.com/wmw-adj...-endlinks.html
If it's just the end links, not too hard at all. If it's the swaybar mount bushings, there is a bit more involved. I replaced my rear swaybar with an ALTA adjustable 19mm recently, and had to drop the whole rear subframe a bit to get it done. I was able to do it at home, however, with the car up on jackstands, and by myself. I am a mechanic for a living, but this MINI is my first, so still learning the ins and outs. I installed some used ALTA adjustable sway bar links during the install. They are Heim joints, and rattle like crazy, just as you have described. Sounds like my hatch is not latched. I will most likely purchase the WMW end links soon. The rattle is getting annoying! The handling, however, is MUCH improved! Live and learn. Motor On!
We offer both stock end links and our Powergrid options which are very resilient units, but Waylen was here first so I digress.
We have any of the above listed failure point replacements on hand, if you need them or help in diagnosing feel free to give us a call.
Nick
Detroit Tuned
586-792-6464
You wouldn't be replacing the endlinks in another 40K miles if you were to use the Powergrid options offered by either WMW or us at Detroit Tuned, other than that there won't be any performance gains or anything like that.
Part of the advantage of going with the H-sport rear bar is that the bushings can be lubed with a grease gun. The mounts have zerk fittings - a nice feature. Hopefully that will extend their life. I give them a shot of grease once or twice a year, usually when doing the swap between summer and winter tires.
A couple of weeks after I installed my RSB I started getting a bad rattle from the back. I tightened up the nuts on the endlinks and it went away. A couple of weeks later it came back, so I backed off the nuts, put some Loctite Blue on the threads, and tightened everything back up. It has been quiet for ~3 years now.
Try it - quick, easy, and cheap. If that wasn't the problem then all it cost you was a tube of Loctite which you should have in the garage anyway.
Good advice on the loctite. I used it when I installed the rear bar. My issue has been play that eventually develops in the ball joint (Heim joint?) of the stock end link. All of the nuts were tight and torqued to spec when the rattle appeared.
The Bentley manual tells you to replace the self-locking nuts every time you remove the end links. The stock nut is apparently intended as a one-time-use item. Unfortunately, when you buy the genuine MINI end link it doesn't come with replacement nuts. Loctite served well as an alternate approach for 3 years until the link itself developed play in the joint.
R50/53 Rear clunk - revisited..
Kahnfucious
20
12-30-2019 05:34 AM
bananamini
04-18-2016 10:40 AM
Rennfahrer555
17
11-26-2015 08:02 PM
