R56 Spark Plugs
#51
Any resolution on this?
I have the same car apparently - R56 2007 Mini Hatch "Justa" N12
Had coils go bad at around 50k on a new motor (long story) and now a couple went out again within a year ... time for plugs
NGK website says all they make that fit are - NGK 90223 PLZKBR7B8DG
Stock specs (and quoted from a great article here) are - Beru 12ZR6SP03
Pelican Parts lists (above links) - Bosch ZQR8SI302 and a slightly different Beru 12ZR6SP2
HALP!
HALP!
888.280.7799 | 6am - 5pm PST
#52
Thanks for your replies!
I've found some NGK 90223's here locally and I think I'm going to give them a shot this afternoon. They seem to be compatible with the parts listed here. Any advice/warnings/info against them?
Additionally, when you check and adjust gaps (I've never done it), are you trying to match the gap listed on the plugs themselves, or is there a different gap specific to the car (not the plugs) that is supposed to be achieved? (and how do you do it?)
Thanks again.
Thanks again.
#53
Which spark plugs? Connected to carbon problem?
Need a recommendation on plugs. Have a 2007 Mini Cooper S with turbo. auto. 88,000 miles. All stock. Has had some engine work done by the local Mini dealer. Has had the carbon problem a few times which was solved with the walnut blasting. So:
- What plug should I use?
- Is NGK the stock plug?
- Does the choice of plug make a difference regarding the carbon buildup?
- What should the gap be?
- What is the socket called that goes with the 12 point spark plug? Bi-hex? It is a 14 mm correct?
#54
Thanks again.
Thanks again.
Plugs: http://www.pelicanparts.com/catalog/..._pg1.htm#item0
Socket: http://www.pelicanparts.com/catalog/..._pg1.htm#item4
Carbon build up article: http://www.pelicanparts.com/techarti...n_Cleaning.htm
If you have anymore spark plug questions feel free to leave a comment on the article, that I mentioned for the above user. I am also just a PM away if you have any questions.
#56
01-30-2016 09:17 AM
01-06-2016 10:48 AM
Tires, Wheels & Brakes
01-06-2016 10:13 AM
