R56 Brake Pad Question/Confirmation
Old 01-30-2016 | 12:19 PM
kxmini's Avatar
kxmini
I've just done the front pads on the wife's '08 Sa and want to make sure I got the pads right. Mine came packaged with both "like" pads packaged together. One set has a hump on them which is for the wear sensor. The other doesn't. Since there is only one sensor on the front, should both of the ones with the hump go on the driver's side or are the ones with the humps supposed to be the inner pad on each side?
Any input will be appreciated.
Old 01-31-2016 | 04:48 PM
kxmini's Avatar
kxmini
Figured it out. There is an inner and outer pad. The ones with the wear sensor "hump" go on the inside.
Old 02-02-2016 | 06:47 PM
Capt_bj's Avatar
Capt_bj
Glad you did figure it out
others have missed this!
Old 02-03-2016 | 12:24 PM
nkfry's Avatar
nkfry
^^I've seen cars come into the shop with the inboard pads both on the passenger side and the brake sensor glued to the drivers side (wrong) inboard pad.
Belle Tire brake job FTW!!
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 02-04-2016 | 11:24 AM
Yep , just for a visual. Hump version are those back pads of the front set.
Eurothrasher
06-23-2016 07:30 PM
j_vincent
02-14-2016 01:31 PM
jesse31
02-03-2016 07:40 AM
Tires, Wheels & Brakes
01-30-2016 10:35 AM
